For context, up until now, we had a business rule in place stopping accounts from being created for users with the same name e.g. Jacob Smith and Jacob Smith.
This business rule has been removed as it was preventing creation of accounts, and the user (e.g. Jacob Smith) has now been created, however, now when trying to move the new object into the same organisational unit/business unit as the original object, this errors and explains 'The object already exists on 'treename'
I suspect it has a configuration behind what I can see and still has detection for duplicated display names?
Unsure on where to check, or how to, if possible, remove this. Any help would be most appreciated!
by (70 points)
Hello Charlie,
The behavior is expected. It comes from AD and is not related to Adaxes. It is not possible to have two accounts with the same name in the same OU. The only option is to use a business rule triggering Before moving a user. The rule should either cancel the operation if a duplicate user is found or generate a unique name for the user being moved. The following tutorial will be helpful: https://www.adaxes.com/help/ValidateModifyUserInputWithScript.
Users are asking if they can change their name to suit preferred names as opposed to birth names? Is this possible?
asked Oct 14, 2024 by Charlie.Evans (70 points)
asked Feb 4 by Keshstew (20 points)
We used to run AD Audit and it would provide additional details on what was locking a user's account (workstation name, application, etc...). Is there are way with Adaxes ... on what is locking an account? Or a way to pull historical data on locked accounts?
asked Nov 16, 2020 by pulsifers (20 points)
Say you have Manager A that has 30 users under them. Manager A leaves and Manager B takes the position. What is the best way to update all 30 users so their new manager is Manager B.
asked Jun 7, 2021 by Jmbrown04 (60 points)
