I am noticing a large amount of PowerShell Transcript files in the Adaxes SA accounts Documents folder.
These are different than the logging feature which has a very separate path of - Program Files\Softerra\Adaxes 3\Service\LogDB.
How is this configured in the administration console? Can I configure these transcripts in any way to manage their space consumption/retention?
by (50 points)
by (17.0k points)
For troubleshooting purposes, please, specify the folder path where the files in question reside. Additionally, please, provide us with a screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment. You can post the screenshot here or send it to us at support@adaxes.com.
by (50 points)
I am only running a single server in my environment. The screenshot has been sent to the support link.
The exact path to the PowerShell Transcripts is - C:\Users\Adaxes SA\Documents
by (17.0k points)
Thank you for the provided details. There are no such settings in Adaxes itself. Most probably, a PowerShell transcription is enabled on the computer. The following Microsoft forum topic might be helpful: https://answers.microsoft.com/en-us/windows/forum/all/powershell-commands-logged-and-saved-as-text-files/7a3c0388-be1e-46f2-93e6-32db74eae66c.
Hi, we just recently installed Adaxes and would like to implement a PowerShell script that I have previously written which cleans up user objects if they have been manually ... : " Insufficient access rights to perform the operation Stack trace: at , ".
asked Oct 2, 2023 by Mark.Monaco (40 points)
Can I get some help with a PowerShell if statement? I'm looking to write something like If the script/custom command is fired via a scheduled task do this. If/Else the ... eq "My Scheduled Task") {"Do Something"} Else {Do Something Different"} Thanks! Ryan
asked Jun 5, 2019 by ryan_breneman (920 points)
Hi so if I have the web-interface setup on my internal server where I did the full install but I also have setup a RODC in DMZ how can I "merge" so that the URLS given ... get the offline/unlock that shows up to link and show/work for the web server on the DMZ
asked Nov 4, 2024 by ckelley (60 points)
I am trialing out the product and having some trouble/challenges with the documentation and my setup for External Web access. I will admit even after searching the webs and speaking ... I need like F5 or something I read in the setup. Thank you for your time
I'm getting a syntax error on this command and I can't figure out what I'm doing wrong: $criteria = New-AdmCriteria "user" {adm-CustomAttributeInt2 -empty $false -and ... AdmCriteria : The criteria is invalid. Syntax error at position 68. At line:1 char:13
asked Oct 17, 2024 by jmatthews (270 points)
