Hi team,
is there any possibility to see "live" which types of tasks/business rules/scripts/etc are running currently on Adaxes Server?
I noticed a CPU of >95% for a while and would like to investigate what is going on and where.
by (2.6k points)
by (16.6k points)
Unfortunately, there is no such possibility. However, you can check what scheduled tasks are currently running. In the Adaxes Administration console, their names are highlighted in bold. Additionally, you can view the Adaxes general log for events that occurred while high CPU usage was observed. Also, you can check how many pending approval requests you currently have: https://www.adaxes.com/help/AllPendingApprovalRequests. If the number is significant (more than 500 pending requests) an additional CPU load might be observed as there are background tasks that process the requests.
by (2.6k points)
Ok, will do, thanks :)
Any plans to have such an overview in future? I know, I can check all scheduled tasks ... but it take a while sometimes to open all folders :D
by (16.6k points)
There are currently no such plans. However, thank you for the suggestion, we will forward it to the corresponding department for consideration.
by (2.6k points)
Morning team,
was this maybe introduced in the new 2025 version?
We still see 100% CPU from time to time for one server and trying to understand why this happens.
Can I somehow identify scheduled task, set to be running on a specific server only?
Unfortunately, it was not.
Have a look at the following help article: https://www.adaxes.com/help/BindScheduledTaskToService.
by (2.6k points)
Ok, sadly - u have this on the roadmap for a future release?
I know this article. I was looking for a nice overview, instead of checking each task.
I found the properties OwnerServiceDnsHostName and IsOwnerServicePermanent from here: https://www.adaxes.com/sdk/IAdmScheduledTask/
With the export script I have this nice overview now: image.png
The feature will definitely not be included into the next major release. As of now, it is being considered by the corresponding department for one of the future releases.
Hello We are using the script you created for us to upload the employees photo based on their employee ID which works fantastic. The script is below: $picturePath = "picture path" # ... I am missing something obvious but can't see how to do it :? Thank you.
asked Jan 9, 2015 by CBurn (700 points)
Hi, I am trying to find a way to have a visual overview of all enabled tasks and when they are running. Example of another app which support this: Is this maybe planned in future?
asked Oct 4, 2023 by wintec01 (2.6k points)
Is it poossibel to run pre and post commands before processing all objects, and then after processing all objects? I have a process that validates if a user account should be ... to be able to tell if the process failing is causing mass disabling of accounts.
asked Jun 19 by sam.webster (410 points)
