When adding Mobile Phone to a custom form, it seems to also inlcude "Mobile Phone (Other)" which we do not want visible in the form. Is there a way to separate the two or simply hide Mobile Phone (Other)? image.png
by (880 points)
by (16.8k points)
The Mobile Phone (directory name mobile) and the Mobile Phone (Other) (directory name otherMobile) are separate properties. You can add/remove them independently from each other. For details on how to customize forms for user creation and editing, have a look at the following tutorial: https://www.adaxes.com/help/CustomizeFormsForUserCreationAndEditing. Make sure to refresh the Web interface page using Ctrl+F5 after saving the changes in the Web interface configurator.
by (880 points)
Thank you for the reply.
What I am seeing is that those fields are not independent. For whatever reason. For example, here is the config of the form
I only have the Mobile Phone field added
However, in the form you can see the Mobile Phone Other field is displayed.
When I remove the Mobile Phone field from the form, the "Other" field is removed as well.
So, I am seeing specific behavior that they are tied in some way in this instance.
Please advise. Happy to open a support ticket if that's best.
For troubleshooting purposes, please, send us (support@adaxes.com) a screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment.
Also, please, provide all the steps you take when creating a user.
by (880 points)
Updating to the latest release resolved this issue.
Dear Is it possible to change the values of a custom attribute (adm-CustomAttributeTextMultiValue4) when selecting a value from another custom attribute (adm-CustomAttributeText1). For ... , 2Latijn, 3Latijn, etc... Is this possible? Sincerly Hilmi Emre Bayat
asked Aug 26, 2019 by hilmiemrebayat (120 points)
Hi Forum, is it possible to hide the other button from the WebGUI? Is it possilbe to hide that on specific home page actions or on the hole Site? Thanks a lot Cheers
asked May 13, 2015 by esoAdxAdmin (650 points)
I'm brand new to this product and am still learning, I apologize for what are presumably bonehead questions. Here goes: 1) We've got a Create Contact action set up ... the custom form Exchange-enables the group? Thanks for the information, A brand new user.
asked Oct 4, 2016 by ctdhelpdesk (190 points)
Hi, I am wondering how cloud connections should be handled across scripts for things to run as smooth as possible. For example, if I disconnect from Graph in ... ) $null = Connect-MicrosoftTeams -AccessTokens @($graphToken, $teamsToken) } Best regards, Martin
asked Mar 14, 2025 by Martin (190 points)
