Unfortunately, there is no easy way to create such a business unit. The thing is that Adaxes attributes (their names start with adm-) cannot be used in search queries. Also, you will need to not only create a separate membership rule in the business unit for each owner, but also clear the list each time. Considering the above, the script and the business unit will simply be useless.
Could you, please, describe where/how you want to use the business unit? Maybe we will be able to suggest an easier and simpler solution.
We would like to have a business unit that is based on an adaxes custom attribute. I don't see a way of doing this. Do you all have any ideas?
asked May 18, 2020 by mark.it.admin (2.3k points)
Dear colleagues, can you please advise if it is possible to create (and update reqularly) business unit of computer objects based on a query to external SQL DB (hostnames stored in SQL)? Thanks!
asked Dec 14, 2022 by Dmytro.Rudyi (920 points)
asked Feb 11, 2025 by wrobin68 (40 points)
