Is there a comparison between the OnPrem user object and Entra user object in the built-in condition? Which determines the most recent inactivity from both environments. Or should a choice be made between the OnPrem domain or Entra based on the Activity scope?
by (140 points)
If you mean the If is inactive for condition, it only checks the target account. It means that if the target account belongs to on-premises AD, the corresponding Microsoft Entra account is never checked. The feature will be present in the next major release.
Can I manage the user that is user by Adaxes to connect to Active Directory with Privilege Access Management (PAM)? Since this user can change user's password, ... would like to manage this user so that PAM can change/rotate the password periodically
The Advanced Search in the Domain Find(CTRL-F3) function allows you to select a custom Active Directory field(added by IT, not a windows default AD field). When you ... helpful to have a Contains, Does not Contain logical operator in the Find function. Thanks!
asked Oct 11, 2012 by mpaul (360 points)
How do I setup Adaxes for Exchange Online Hybrid mode? When I look at one of the users that has been migrated to Exchange Online I get the message of The operation couldn't be performed because object couldn't be found on domain controller.
asked Dec 5, 2019 by Lucas.Miller (20 points)
I want to make a custom field in which you can select a person from the active directory, is this possible? For example, as in the field manager
asked Nov 18, 2022 by Alvares (100 points)
