Is there an option to set a default sort order of the results of a query in the web interface? For example, if I want to allow someone to select from a list of groups, but would always like the list to be sorted in reverse order?
I know the user can click on the column to sort, but I would like to control the initial results.
by (420 points)
No, there is no such possibility.
I've got an Adaxes scheduled task that will export records out of AD into a JSON text file. All is working well except for the ability to sort the objects returned ... $exportFile "`n]" $Context.LogMessage("Total records written = " + $count, "Information")
asked Sep 11, 2015 by sandramnc (870 points)
Hello, I am having issues with Reports not matching the results in the Console and Web UI. Below, you can see that the Adaxes Console only has 8 Workstations listed, but on the ... UI. Any help is appreciated, let me know if there is any questions. Thank You!
asked Jul 23, 2023 by Edogstraus00 (590 points)
I have Search configured for one of our web interfaces. One of the fields that can be searched is a custom attribute admCustomAttributeText4 (with a friendly name of ... are definitely some accounts with that attribute populated. Is this behaving as designed?
asked Sep 19, 2018 by sandramnc (870 points)
We manage several domains, and some of them are complex and there is no way to have adaxes (or programmatically) complete all of the steps required to deprovision a user. I ... the bottom of the Deprovision results, but I am open to ideas. Thanks very much.
asked Jan 12, 2018 by Jasonmh (540 points)
I have a dropdown-field on the web surface, which is populated by a script. The script looks up all groups in a specific OU and displays them. In the Property Pattern ... random order. What should i do to show the groups in alphabetical order in the portal?
asked Sep 15, 2020 by lohnag (160 points)
