I have a dropdown-field on the web surface, which is populated by a script. The script looks up all groups in a specific OU and displays them. In the Property Pattern all groups are displayed in alphabetical order. image.png
But on the web portal the groups are shown in a random order.
What should i do to show the groups in alphabetical order in the portal?
by (160 points)
The thing is that the script adds values to the Property Pattern is the order groups are found during the search and when you open editing of the setting, it gets automatically sorted. If you refresh the Web Interface page after that, you will also see sorted values. Unfortunately, there is no possibility to change the behavior. To achieve the desired sorting, you can sort the values in the script before adding them to the Property Pattern. If you have issues updating the script, please, post it here or send to us (support[at]adaxes.com) and we will help you.
by (160 points)
I'm not sure how to update the script. Thanks for your help! The following script is in a custom command which will be executed by a scheduled task every 30 min
$patternName = "Benutzer-Muster" # TODO: modify me
$propertyToUpdate = "extensionAttribute5" # TODO: modify me
function SearchObjects($filter, $containerPath)
    $searcher = $Context.BindToObject($containerPath)
        return ,$searchResults
        # Release resources
# Get all groups in the target OU
$groupSearchResults = SearchObjects "(objectCategory=group)" $Context.TargetObject.AdsPath
# Exit if no groups found
if ($groupSearchResults.Length -eq 0)
# Get group names
$groupNames = New-Object System.Collections.ArrayList
foreach ($searchResult in $groupSearchResults)
    $groupNames.Add($searchResult.Properties["name"].Value)
# Find Property Pattern
$propertyPatternsPath = $Context.GetWellKnownContainerPath("PropertyPatterns")
$patternSearchResults = SearchObjects "(&(objectCategory=adm-PropertyPattern)(name=$patternName))" $propertyPatternsPath
if ($patternSearchResults.Length -gt 1)
    $Context.LogMessage("Found more than one Property Pattern with name '$patternName'.", "Warning")
if ($patternSearchResults.Length -eq 0)
    $Context.LogMessage("Property Pattern '$patternName' does not exist.", "Error")
# Bind to the Property Pattern
$pattern = $Context.BindToObject($patternSearchResults[0].AdsPath)
# Delete the pattern item for the property
foreach ($item in $pattern.Items)
    if ($item.PropertyName -ieq $propertyToUpdate)
        $pattern.Items.Remove($item)
        break
# Create list of values for the property
$item = $pattern.Items.Create()
$item.PropertyName = $propertyToUpdate
$constraint = $constraints.Create(
    "ADM_PROPERTYCONSTRAINTTYPE_VALUERANGE")
$constraint.AreValuesDenied = $False
$constraint.Values = $groupNames.ToArray()
$constraints.Add($constraint)
$item.SetConstraints($constraints)
# Update Property Pattern
$item.SetInfo()
$pattern.Items.Add($item)
Thank you for the confirmation. Here is the updated script.
        # Release resources
# Get group names
        break
$groupNames.Sort()
$item.SetInfo()
by (160 points)
Thanks for your help, works perfect.
asked Jun 4, 2024 by KEME (150 points)
asked Oct 5, 2022 by mightycabal (1.2k points)
