I am trying to run a script that uses the Vmware.Hv.Helper module to connect to a VMWare horizons server and pull usage data. After updating to 2025, this script fails and I am wondering if we can force Adaxes to use PS5.1 instead of 7.
How does adaxes know which version of powershell to use for a script?
by (120 points)
by (190 points)
Same here, the Whats new article tells that we can choose the powershell version that will be executed?
As it is mentioned below, this is a mistake in the What’s New article. We will fix it as soon as possible.
At the same time, we confirm that starting from version 2025.1, Adaxes only supports PowerShell 7.
Adaxes 2025.1 only users PowerShell 7. It does not use PowerShell 5 at all. As such, you need to install the version of the module compatible with PowerShell 7 on the computers where Adaxes service runs and remove all the other versions.
by (90 points)
I'm also having similar issues with scripts that load v5 modules - thought I would be ok based on the below:
https://www.adaxes.com/info_whats-new.htm#powershell_7_support
"That's why scripts in Adaxes workflows now support PowerShell 7 alongside PowerShell 5.1, opening the door to cmdlets from PS7-only modules."
Not sure who to believe :D
Thank you for pointing out the mistake. We will correct the What’s New article. Sorry for the inconvenience.
Are there plans to add support for powershell 5.1? Microsoft scrapped a lot of functionality in powershell 7 and a hybrid environment can not be managed in powershell 7 (as far as I can find)
As of now, there are no such plans.
It's shame that powershell 5.1 isn't supported, we built a whole library of automation scripts that have broken when we upgraded to 7 and now face the task of rewriting them all.
Thank you for your input, we will pass the details to the corresponding department for consideration. We apologize for the inconvenience. At the same time, most modules not support are compatible with PowerShell 7 and you just need to install the proper version of the module on the computer (s) where Adaxes service runs.
Hi team, We are running version 2025.1 - 3.17.23904.0 with three servers and one SQL server. Two of the three servers are used for web access behind a load ... issues if we revert to the previous version (internal database/settings and SQL logging database)?
asked Jun 1 by wintec01 (2.7k points)
I'm seeing this error when I run a user deprovision. It still executes the script but nobody likes errors! Run PowerShell Script 'DuoDeprovisionExport' For the user. The term ' ... running an export script in the first place for my Duo user info. ) Thanks.
asked Feb 19, 2020 by rainamaina (60 points)
Hi there, we have some custom commands that need the enter-pssession with -sshtransport which is only available in PWSH7. Is it supported to install powershell7 right on the adaxes server? Kind regards, Constantin
asked Mar 3, 2022 by Constey (190 points)
Issue The Active Directory Federation Services (ADFS) master key that decrypts ADFS certificates is stored in Active Directory, in the thumbnailPhoto attribute of a contact object ... ,CN=Program Data,DC=domain,DC=com container via native AD access control.
asked Mar 28, 2025 by Adaxes (660 points)
We have a fleet of Macbooks that use NoMAD to handle AD Authentiction and syncronization. How can we use Adaxes to handle the Password reset utility with these users. If they ... resync will be needed. Anybody else doing this or have a solution to the above?
asked May 13, 2020 by jcalvert (60 points)
