Hi team,
this script is with the new version not working anymore. Can you please update it? https://www.adaxes.com/script-repository/search-and-replace-text-in-adaxes-scripts-s224.htm
Cannot find an overload for "GetOperationName" and the argument count: "3".
At ADX - Search and replace text in Adaxes scripts.ps1:44 char:13
+             $actionDescription = $objectAction.GetOperationName("The  ...
    + CategoryInfo          : NotSpecified: (:) [], MethodException
    + FullyQualifiedErrorId : MethodCountCouldNotFindBest
Unable to find type [Softerra.Adaxes.Utils.ObjectNameHelper].
At ADX - Search and replace text in Adaxes scripts.ps1:164 char:30
+ ... $objectDisplayName = [Softerra.Adaxes.Utils.ObjectNameHelper]::GetObj ...
    + CategoryInfo          : InvalidOperation: (Softerra.Adaxes.Utils.ObjectNameHelper:TypeName) [], RuntimeException
    + FullyQualifiedErrorId : TypeNotFound
by (2.7k points)
As pre our check, the script works just fine. How exactly did you execute it? Please, provide the exact command as well. Any additional details will be helpful.
by (2.7k points)
I am running it on Adaxes Server within Powershell ISE.
This is the script I am running
param(
    [Parameter(Mandatory=$true,Position=1)]
    [String]$textToSearch,
    [Parameter(Position=2)]
    [String]$replaceWith
[void][Reflection.Assembly]::LoadWithPartialName("Softerra.Adaxes.Adsi")
# A hash table with types of configuration objects and their aliases
$configurationObjectInfos = @{
    "BusinessRules" = "adm-BusinessRule";
    "CustomCommands" = "adm-CustomCommand";
    "ScheduledTasks" = "adm-ScheduledTask";
function CheakActions ($actions, $textToSearch, $replaceWith, $objectType, $actionConditionList, $actionConditionCount)
    foreach ($action in $actions)
        if ($action.Class -ne "adm-RunScriptAction")
        # Check whether the script contains the specified text
        $objectAction = $action.GetAction()
        $script = $objectAction.Script
        if (!($script.ToLower().Contains($textToSearch.ToLower())))
        # Get action description
        $actionDescription = $objectAction.CustomDescription
        if ([System.String]::IsNullOrEmpty($actionDescription))
            $actionDescription = $objectAction.GetOperationName("The $objectType", $NULL,
                "ADM_ACTIONNAMEFORMAT_SPECIFIC,
                ADM_ACTIONNAMEFORMAT_CAPITALLETTER,
                ADM_ACTIONNAMEFORMAT_PRESENTTENSE,
                ADM_ACTIONNAMEFORMAT_SPECIFICINFOINADDITIONALDATA")
        [void]$actionConditionList.AppendLine("`tAction: $actionDescription")
        $actionConditionCount.ActionCount++
        if ([System.String]::IsNullOrEmpty($replaceWith))
        # Update the action
        $script = $script.Replace($textToSearch, $replaceWith)
        $objectAction.Script = $script
        $action.SetAction($objectAction)
        $action.SetInfo()
function CheckActionAndConditionSets($actionsAndConditionsSets, $textToSearch, $replaceWith, $objectType, $actionConditionList, $actionConditionCount, $isElseIfBlock)
    foreach ($actionsAndConditionsSet in $actionsAndConditionsSets)
        # Check actions
        CheakActions $actionsAndConditionsSet.Actions $textToSearch $replaceWith $objectType $actionConditionList $actionConditionCount
        # Check conditions
        foreach ($condition in $actionsAndConditionsSet.Conditions)
            if ($condition.Class -ne "adm-ScriptCondition")
            # Check whether the script contains the specified string
            $objectCondition = $condition.GetCondition()
            $script = $objectCondition.Script
            # Get condition description
            $conditionDescription = $objectCondition.GetDescription($NULL)
            [void]$actionConditionList.AppendLine("`tCondition: $conditionDescription")
            $actionConditionCount.ConditionCount++
            # Update Condition
            $objectCondition.Script = $script
            $condition.SetCondition($objectCondition)
            $condition.SetInfo()
        if ($isElseIfBlock)
        CheckActionAndConditionSets $actionsAndConditionsSet.ElseIfConditionedActions $textToSearch $replaceWith $objectType $actionConditionList $actionConditionCount $True
        if ($actionsAndConditionsSet.ElseActions.Count -ne 0)
            CheakActions $actionsAndConditionsSet.ElseActions $textToSearch $replaceWith $objectType $actionConditionList $actionConditionCount
# Connect to Adaxes Service
$totalActions = 0
$totalConditions = 0
foreach ($alias in $configurationObjectInfos.Keys)
    # Bind to the configuration container that contains objects of the current type
    $configurationContainerPath = $admService.Backend.GetConfigurationContainerPath($alias)
    $configurationContainer = $admService.OpenObject($configurationContainerPath, $NULL, $NULL, 0)
    # Find configuration objects of the current type
    $type = $configurationObjectInfos[$alias]
    $configurationContainer.SearchFilter =  "(objectCategory=$type)"
    $configurationContainer.PageSize = 500
    $configurationContainer.SearchScope = "ADS_SCOPE_SUBTREE"
    $configurationContainer.ReferralChasing = "ADS_CHASE_REFERRALS_NEVER"
    $searcherResult = $configurationContainer.ExecuteSearch()
    $objects = $searcherResult.FetchAll()
    $searcherResult.Dispose()
    # Search scripts for the specified string
    foreach ($objectID in $objects)
        # Bind to the Business Rule, Custom Command or Scheduled Task
        $object = $admService.OpenObject($objectID.AdsPath, $NULL, $NULL, 0)
        $actionConditionList = New-Object "System.Text.StringBuilder"
        # Perform search in scripts
        $actionConditionCount = @{ ActionCount = 0; ConditionCount = 0 }
        CheckActionAndConditionSets $object.ConditionedActions $textToSearch $replaceWith $object.ObjectType $actionConditionList $actionConditionCount $False
        if (($actionConditionCount.ActionCount -eq 0) -and ($actionConditionCount.ConditionCount -eq 0))
        # Output scripts found
        $objectDisplayName = [Softerra.Adaxes.Utils.ObjectNameHelper]::GetObjectName($objectID.AdsPath, "IncludeParentPath")
        Write-Host "Object name: $objectDisplayName"
        #Write-Host "Action/Condition description:"
        Write-Host $actionConditionList.ToString()
        if ($actionConditionCount.ActionCount -eq 0)
            $totalConditions = $totalConditions + $actionConditionCount.ConditionCount
            #Write-Host "Search text found in" $actionConditionCount.ConditionCount "condition(s)"
            #Write-Host
        elseif ($actionConditionCount.ConditionCount -eq 0)
            $totalActions = $totalActions + $actionConditionCount.ActionCount
            #Write-Host "Search text found in" $actionConditionCount.ActionCount "action(s)"
            #Write-Host
            Write-Host
    Write-Host "Total actions found:" $totalActions
    Write-Host "Total conditions found:" $totalConditions
    Write-Host "Search text replaced in $totalActions actions."
    Write-Host "Search text replaced in $totalConditions conditions."
My console output
PS C:\Users\service-adaxes> \XX\Adaxes Server Scripts\ADX - Search and replace text in Adaxes scripts.ps1
cmdlet ADX - Search and replace text in Adaxes scripts.ps1 at command pipeline position 1
Supply values for the following parameters:
textToSearch: get-aduser
At \XX\Adaxes Server Scripts\ADX - Search and replace text in Adaxes scripts.ps1:44 char:13
At \XX\Adaxes Server Scripts\ADX - Search and replace text in Adaxes scripts.ps1:164 char:30
Object name:
    Action:
Object name:
    Action:
Thank you for the provided details. We updated the script in the repository according to the changes introduced in Adaxes 2025.1. Sorry for the inconvenience.
by (2.7k points)
Thank you kindly. It is working now : )
asked May 13, 2025 by msinger (230 points)
Ever since upgrading to 3.16.21906.0 the script here no longer works: https://www.adaxes.com/script-repository/move-mailbox-tofrom-microsoft-365-s579.htm Not sure what the issue is as I can't find any errors in the log.
asked Nov 16, 2023 by curtisa (350 points)
Hi all, We had patches installed on our Adaxes 2018.2, 2008 R2 server the other night. As part of that, Windows Management Framework ... -44db-b83c-3a0696611ddd/could-not-load-file-or-assembly-systemmanagementautomation-version3000?forum=virtualmachinemanager
asked Sep 26, 2019 by AllianceIT (150 points)
Hi, I have this Script to check if a condition is met # The condition is met if $Context.ConditionIsMet is set to $True. $Context.ConditionIsMet = $False $inputString = " ... or issue with this match function using in a "if script returns true" condition?
asked Oct 31, 2024 by wintec01 (2.7k points)
