We need to have a process to revoke the access token used by Okta for end users.
by (100 points)
Hello William,
What exactly do you mean by access token used by Okta? Is it something stored in user properties?
by (100 points)
Sorry, your system only allowed me to place this under the AD questions.
From Adaxes I need to make a call to Okta to revoke the access token that is created.
Here is a URL for the process, I just need to determine the best method to use within Adaxes to make this call.
https://developer.okta.com/docs/api/openapi/okta-management/management/tag/User/#request-example-35
by (100 points)
Thank you. I will work on a custom script to execute this.
Hello William,
Thank you for clarifying. That is something that can only be done using a custom script if Okta supports such requests at all. Unfortunately, we do not have anything like that.
I am trying to view AD authentication logs to see a user account's authentication attempts. Can this be done in Adaxes?
asked Dec 30, 2021 by Tfarmer (160 points)
I'm trying to schedule a report to look in a few specific OUs. Currently "Look in" location only allows for single instance or multiple drop downs. How do I schedule multiple OU locations without creating multiple reports?
asked Jul 2, 2020 by Al (20 points)
asked Feb 4 by Keshstew (20 points)
For context, up until now, we had a business rule in place stopping accounts from being created for users with the same name e.g. Jacob Smith and Jacob Smith. This business ... , or how to, if possible, remove this. Any help would be most appreciated! Thanks
asked Oct 22, 2024 by Charlie.Evans (70 points)
Users are asking if they can change their name to suit preferred names as opposed to birth names? Is this possible?
asked Oct 14, 2024 by Charlie.Evans (70 points)
