Hi *,
has anybody implemented a sharemanagement?
We want to manage file shares not only for users but for departments or projects.
Is that possible? How can I create an object representing that share (and add further details like owner, department, description, write group, read group,...)?
Thanks in advance!
by (200 points)
Yes, it is possible. To create a Shared folder in Adaxes Administration Console:
  1. Navigate to and right-click the OU/Container where you want to create the Shared folder.
  2. In the context menu, navigate to New and click Shared Folder.
  3. Follow the instructions in the wizard that opens.
To display existing Shared folders in Adaxes Web Interface:
  3. In the left pane, click Browsing.
  4. In the Filter Options section, click Add.
  5. Select the Volume Object type and click OK.
  6. Optionally, select an icon for the Object type and click OK.
  7. Save the changes.
To have the possibility to create and modify Shared folders using Adaxes Web Interface, you need to customize corresponding forms for the Volume Object type. For details, see https://www.adaxes.com/tutorials_WebInt ... diting.htm.
by (200 points)
Thanks for your fast help!
How can I search for the volume object type? I can only choose "People, Groups, Computers, OUs" in the web config interface.
Is it possible to allow the search for volumes?
Thanks in advance!
Yes, it is possible. You will need to add the volume object type to the Advanced Search configuration using the below script. Execute the script in Windows PowerShell on the computer where Adaxes service is installed. When prompted, specify the credentials of the Adaxes service account.
In the script:
  • $webUIConfigurationName - specifies the name of the Web Interface configuration of which will be updated;
  • $objectTypes - specifies an array of object types that will be added to the Advanced Search configuration;
  • $displayName - specifies the display name for the object types specified in $objectTypes;
  • $searchByDefault - specifies whether searching the object types will be enabled by default.
  • $visible - specifies whether the new entry will be visible when performing Advanced search in the Web Interface.
$webUIConfigurationName = "HelpDesk" # TODO: modify me
$objectTypes = @("volume") # TODO: modify me
$displayName = "Shared folders" # TODO: modify me
$searchByDefault = $True # TODO: modify me
$visible = $True # TODO: modify me
# Bind to Adaxes service
# Get Web Interface configuration
$webuiConfigPath = $admService.Backend.GetConfigurationContainerPath(
    "WebUIConfigurationContainer")
$credential = Get-Credential
$webuiConfigContainer = $admService.OpenObject($webuiConfigPath, $credential.UserName, $credential.GetNetworkCredential().Password, 0)
$webUIConfiguration = $webuiConfigContainer.GetConfiguration($webUIConfigurationName)
$searchSettings = $webUIConfiguration.SearchSettings
$advancedSearchObjectTypes = $searchSettings.AdvancedSearchObjectTypes
foreach ($objectType in $advancedSearchObjectTypes)
    if (@(Compare-Object $objectType.DirectoryObjectTypes $objectTypes).Length -eq 0)
        $message = "Object types array specified for: " + $objectType.DisplayName
        Write-Warning $message
# Add object type to Advanced Search
$searchObjectType = New-Object Softerra.Adaxes.Management.WebUI.Search.AdmWebUISearchObjectType
$searchObjectType.DirectoryObjectTypes = $objectTypes
$searchObjectType.DisplayName = $displayName
$searchObjectType.SearchByDefault = $searchByDefault
$searchObjectType.Visible = $visible
$advancedSearchObjectTypes += $searchObjectType
$searchSettings.AdvancedSearchObjectTypes = $advancedSearchObjectTypes
$webUIConfiguration.SearchSettings = $searchSettings
# Save the changes
$webUIConfiguration.SetInfo()
by (200 points)
Nice, thanks again! :)
Microsoft supports decommissioning your last on prem Exchange Server and managing receipients using Windows PowerShell. See: https://learn.microsoft.com/en-us/exchange/manage- ... . Can the Exchange Management Tools be installed safely on an Adaxes Server?
asked Apr 22 by RayBilyk (310 points)
Hello I am looking fro information on managing custom attributes in Adaxes. I would like to create two custom attributes: Self Service Enrollment Stauts Object Type While ... " column above is not a slectable attribute for some reason. Software version:
asked Dec 10, 2025 by apruitt (580 points)
I was wondering if the abilities below are configurable for Domain Admin users in the web portal: Mass password reset Assign different passwords per person, so it's not the same ... to our users, instead of me writing a powershell script to do this. Thank you!
asked Jul 18, 2025 by apruitt (580 points)
What are the minimum security role requirements required for vieiwing management history within the Web GUI. I have granted the following to any authenticated users They are ... permissions should be required for allowing viewing this report in the Web GUI.
asked Feb 10, 2025 by KoleArmstrong (170 points)
asked Sep 18, 2024 by felix (210 points)
