Is it possible to to get all users with a custom attribute defined?
In PowerShell I'd be doing this:
$s = get-aduser -filter 'Description -like "Sales Engineer"' | Select Name
But Instead of filtering on Description I'd want to filter on adm-CustomAttributeBoolean1
The dream was that this would work:
$s = get-admuser -filter 'adm-CustomAttributeBoolean1 -like "True"' | Select Name
Is this possible?
Thanks for any help or tips!
by (300 points)
Hello Jake,
There is no possibility to use Adaxes custom attributes in LDAP search filters. However, you can use search to find the users you need and then filter search results by the value of the custom attribute you need. For examples, have a look at the following scripts from our repository:
Users whose Adaxes custom attribute is set to a specific value
Users whose Adaxes custom attribute is not empty
Hello. I got a script that when E-mail forwarding is set, it automatically sends an email to the person that will recieve the forwarded emails for 6 months. But I'd like ... what to put in the xxxxxxx so it would take the account that im running command on.
asked Jun 3, 2024 by EdgarsABG (110 points)
Is there a comparison between the OnPrem user object and Entra user object in the built-in condition? Which determines the most recent inactivity from both environments. Or should a choice be made between the OnPrem domain or Entra based on the Activity scope?
asked Dec 13, 2024 by IwistIT (140 points)
Hi, during account creation we store a user/requester DN in field adm-CustomAttributeObject2 If now this requester is disabled, I want to find all users in AD ... field. I found some articles and scripts, but nothing working as expected.
asked Feb 27, 2024 by wintec01 (2.7k points)
Hi, I have a custom attribute for new hire start date with the following configuration : When i retrieve the attribute it is always returned as the day before, as an ... but would like to understand what is going on here, any input would be appreciated.
asked Sep 13, 2019 by digimortal (240 points)
