We are running Adaxes 3.18.25007.0 with a managed domain example.local that has two domain controllers, DCnode1 and DCnode2. The domain was registered by domain name only (no specific DC), and SSL Usage is set to "Always" in the managed domain properties.
Our use case: during a planned maintenance one of the two DCs was shut down. The Adaxes service did not seem to notice. It kept trying to use the DC that was offline and only worked again after manual intervention. Our goal is for Adaxes to keep working automatically when one of the two DCs is unavailable, whether for maintenance or a failure.
We read the article "Use specific domain controllers" (https://www.adaxes.com/help/UseSpecificDCs/) and this older thread: https://www.adaxes.com/questions/721/adaxes-connects-to-any-domain-controller. In 2014 you explained that allowedDomainControllers is an ordered preference list ("connect to DC1; if DC1 is not available, use DC3..."), and that the domain is marked as not operational if none of the listed DCs is available.
Our questions:
  1. Is the behaviour described in that 2014 thread still valid in the current version of Adaxes?
  2. Failover with an already established connection: if Adaxes is already connected to DCnode1 and DCnode1 goes offline, does Adaxes detect it and switch to DCnode2 automatically? Is availability checked on every connection or only at service startup? How long does the switch roughly take (timeouts, retries), and is a service restart ever required?
  3. Default behaviour without allowedDomainControllers: when the domain is registered by name only and the DC in use becomes unreachable, does Adaxes re-discover another DC on its own, and how quickly?
  4. Load-balanced LDAPS endpoint: our network team provides an LDAPS endpoint behind a load balancer (F5) that balances both DCs. Is it supported to point Adaxes at such an endpoint, either in the domain registration or in allowedDomainControllers, instead of the individual DCs? If not, what is the recommended approach to get automatic failover?
Thank you in advance for your help.
Best regards, Leonardo Bressan
by (160 points)
Hello Leonardo,
Yes, it is still valid as described in the help article.
Yes, it switches automatically.
It is performed whenever a request is executed from Adaxes towards the domain. It can be something manual (e.g. updating object properties) or automatic (e.g. actions performed by a scheduled task).
The switch is performed instantly.
By default, Adaxes relies on the Domain Controller locator algorithm to locate domain controllers for a managed domain. That is what gives Adaxes available domain controllers if the Softerra.Adaxes.Service.dll.config file is not updated accordingly.
Unfortunately, there is no such possibility. Specifying DCs in the Softerra.Adaxes.Service.dll.config file is the only option. Pay attention that all the required ports must be open for all the corresponding DCs: https://www.adaxes.com/help/AdaxesNetworkUsage.
They can navigate to both the user or the group within the ADAXES web interface without issue. They can then either Add to Group or Add Member but the resulting ... something to the web interface which prevents changing the lookup domain. Any ideas? Thanks!
asked Apr 9, 2020 by VTPatsFan (610 points)
asked Oct 5, 2022 by mightycabal (1.2k points)
We are planning to use Adaxes in our environment and before proceeding, we need to understand the firewall port requirements for Adaxes service to work. What are the firewall ports needed between Adaxes and AD domain controller?
asked Jan 24, 2024 by Renugopal (120 points)
This issue may occur when activating a Microsoft 365 account for a user and assigning licenses in the same action. Symptoms The following error is returned: License assignment ... a program or PowerShell script action that adds a 1-minute delay between them.
asked Apr 23 by Adaxes (660 points)
Within Property Patterns, I need a way to fill in 'User Logon Name' with the contents of the mail field only up until the @ sign. The requirement is due to the need ... , have it populate the User Logon Name field with 'accountsreceivable'. How can I do this?
asked Sep 16, 2016 by ajrechk (480 points)
