The column that shows the member of property of a user is to small and it seems not poosible to adjust its size.
How to solve this issue?
Thanks in adavnce!
Mic
by (200 points)
Hello Mic,
There is no possibility to adjust the column width, this behavior is by design. As a solution, you can decrease the number of columns in the Member Of section. For information on how to do that, see https://www.adaxes.com/tutorials_WebInt ... tLists.htm. On step 5 of the tutorial, select Member Of section.
In the next version of Adaxes, Members, Member Of and Child objects sections will be resizable, will display more objects by default, you will be able to specify default sorting and grouping for the sections, etc.
by (200 points)
Thank you.
by (90 points)
Our users would really appreciate a larger 'Member Of' section.
When will the next release be available?
Unfortunately, there are no exact dates for the next release of Adaxes yet. Currently, it is planned for the first half or 2019.
Adaxes 2019.1 which includes the possibility to resize the Members, Member Of and Child objects sections in Adaxes Web Interface is now available. You can download it here.
What's New | Upgrade Instructions
Hi, after upgrading to 2025.1 technicians in our helpdesk role is missing the 'Add' button on the 'Member Of' section of the User screen. They have full write ... group membership from the Group screen. Administrator users are still able to see the button.
asked May 1, 2025 by Allister (90 points)
Hello We are using the Computer Manager security role and have given access to this group of staff to a web console, what I can't get working is getting it to display the ... else like OS, service pack, role are displaying OK. Can you help please? Thank you.
asked Feb 4, 2015 by CBurn (700 points)
I think this started happening back in August when we updated to the current version (3.13.18.106.0). We are not sure though because this only affects the web page ... We would prefer not to allow access through a firewall for this. Screenshot of the error:
asked Nov 23, 2020 by mark.it.admin (2.3k points)
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8, 2024 by Handernye (120 points)
We're having an issue where removing groups from a user object gets executed in AD and also reflected if browsing through the Adaxes Admin Console to the user object, but ... cache, but that didn't make a difference. Does anybody experience this issue, too?
asked Dec 12, 2016 by rsc (40 points)
