Hey
I found this code for my Custom Command to autofill Description. Does anyone know how to modify it to handle grandparent i.e. go two levels up?
$parent = $Context.BindToObject($Context.TargetObject.Parent)
$Context.TargetObject.Put("Description", $parent.Get("name"))
Best Regards
Debarase
by (100 points)
Hello Debarase,
You can use the following script to update the Description of an object with the name of its grand parent.
# Get grand parent DN
$grnadParentDN = (New-Object "Softerra.Adaxes.Ldap.DN" "%adm-ParentDN%").Parent
if ($grnadParentDN.Leaf.Type -eq "DC")
    $Context.LogMessage("Grand parent of object %fullname% is not an OU or container.", "Warning")
# Update object description
$Context.TargetObject.Put("Description", $grnadParentDN.Leaf.Value)
by (100 points)
Perfekt, it works beautifully
I've had a couple custom commands configured since 6/2023 and they've been working just fine up until recently (sometime within the past few weeks or so). Here's a general ... something obvious here. But I can't make sense of why this is suddenly an issue.
asked Mar 20, 2024 by msinger (230 points)
Hello, I am looking for a way to add custom text to a custom command. Optimally in HTML format so I can create links. A similar request was made here: https://www. ... info icon. It would be great if you add this possibility in the next version. regards pudong
asked May 6, 2022 by pudong (680 points)
I have centralized some of my scheduled tasks in Adaxes; a couple not related to AD. One powershell command runs every minute and copies a file between two systems. Is ... to prevent this specific custom command from logging the action as it is quite noisy.
asked Aug 30, 2021 by jbadry (450 points)
When creating custom commands you have to select the object type. What is the object type for a Business Unit? It doesn't seem to be OU or Container as I can not select ... execute my script against. I've been searching the site and can not find this detail.
asked Jul 5, 2021 by ComputerHabit (810 points)
I currently have a Custom Command that is configured for User objects, but I would like to perform actions against a Computer object in the same command. E.g. I have a ... Users, there's no Action Set to disable Computers. Is there a workaround here? Thanks!
asked Jul 28, 2020 by bavery (250 points)
