Is there an option to currently run a Custom Command in a WhatIf scenario like you can with a powershell command? It'd be nice to be able to validate what you have built before actually doing it, possibly saving a big issue from happening, and giving us piece of mind.
Thanks.
by (1.5k points)
Unfortunately, there is no such option.
Hi there, i've a custom command with multiple powershell scripts (for clearance reasons). If for example the frist script produces an error i Write an Error but the next ... tried with an simple exit 1; I only Write-Errors on issues. Kind regards, Constantin
asked Jul 23, 2021 by Constey (190 points)
I have a business rule that needs to needs to remember the current setting of an attribute (msDS-PrimaryComputer) after the attribute is changed. This attribute stores the ... to the user settings which of course means that the attribute has already changed.
asked May 19 by stevehalvorson (150 points)
Currently when you create a Custom command you have to do two things one I have to go to conf manager page and uncheck and I have to put zz to make it funnel to the ... will never be an action button just a recall to buttons I provide for people to use.
asked Mar 5 by Brian (40 points)
Hi The Custom Commands edil Box Send more symbols. If type the symbols $ the will output '$ How can I fix it? Input Output
asked May 31, 2022 by will.chc.join (90 points)
3,717 questions
8,592 comments
549,995 users
