We are creating an in-house developed portal for our customers. One of the features in our portal will be the user management which will be provided through Adaxes Web Interface. The customer will log in to our developed portal through AD credentials. Is there a way to pass AD credentials off to Adaxes' Web Interface? In a way of a cookie? session? URL encoded string?
Any information will help the developers on our end.
by (80 points)
It is possible to pass user credentials programmatically to Adaxes Web Interface. Here you have 2 options:
1. Call the SignIn method on the Adaxes authentication web service (AuthenticationService.asmx).
Using ASP.NET AJAX Extentions:
   Sys.Net.WebServiceProxy.invoke("/AdaxesAdmin/AuthenticationService.asmx", "SignIn", false,
   {'username': username, 'password': password}, function(){location.href = "/AdaxesAdmin/Default.aspx"},
    function(error){alert(error.get_message())});
Using jQuery:
            $.ajax({
            'type':'POST',
            'url': "/AdaxesAdmin/AuthenticationService.asmx/SignIn",
            'data': "{username: \""+ username + "\", password: \"" + password + "\"}",
            'dataType': "json",
            'contentType': "application/json; charset=utf-8",
            'success': function(){location.href = "/AdaxesAdmin/Default.aspx"},
            'error': function(jqXHR, textStatus, errorThrown)
               var responseJson = $.parseJSON(jqXHR.responseText);
               alert(responseJson.Message);
Please note that this method will work only if your web site and Adaxes Web Interface are hosted in the same domain.
2. Pass user name and password in the sign in URL:
http://server.com/AdaxesAdmin/SignIn.aspx?username=user@domain.com&password=pwd
by (80 points)
Since we are developing our in house application in PHP, I will keep every one updated if we decide to use the PHP Microsoft AJAX Library located at http://phpmsajax.codeplex.com
by (0 points)
Is something like this still possible with recent versions of Adaxes? e.g. with 2018.2
Thanks,
Chris
by (0 points)
Nevermind, I see that it is. You just post to /SignIn instead.
-Chris
Is it possible to pass credentials to Adaxes web interface in order to skip log on?
asked Sep 7, 2011 by abdutal (110 points)
asked Oct 10, 2025 by apruitt (510 points)
asked Apr 10, 2024 by cewilson (300 points)
Hi I've created a new adaxes configuration and limited access to do things based on the 'actions' section: only create, modify, delete contacts are available. Added myself to ... since updating to version 3.16.21408.0. How can I resolve this error? Thanks
asked Oct 4, 2023 by cheezoid (20 points)
