Is it possible to run a report of all employees that report up to a manager, regardless of levels in between (sort of an org chart report)? For instance, the CIO has 4 VPs that report to him. Those 4 VPs have 4 directors each that report to them, those directors... and so on. If I run a report on the CIO, it would would show the VPs, the Directors, the Managers, the Employees, etc, all rolled up under the CIO. Similar to the "Show indirect members" box can be used for group members to expand out members of nested groups.
Thank you!
by (360 points)
Update 2018
Starting with Adaxes 2018.1 you can use a built-in report, Subordinates of user. By default, the report is located in container Reports\All Reports\users\Managers and Subordinates. Also, you can create custom reports of your own. For details, see https://www.adaxes.com/tutorials_ActiveDirectoryManagement_CreateReport.htm.
Original
There is no built in report for this purpose, but you can accomplish the task with PowerShell scripts. You can create a PowerShell script that will build a list of all subordinates of a user in the form of an HTML report sent to the initiator's email. Then, you can use the script with a Custom Command (to generate and send the report on demand) or with a Scheduled Task (to generate a report on schedule).
We can help you with the script, but for this purpose we need to know which properties of the subordinates need to be included in the report.
By the way, thanks for a good suggestion! We've decided to include the functionality to generate such a report in one of our future releases.
by (360 points)
I figured it would be possible with Powershell, but my skills are relatively basic, so any scripting assistance would be appreciated. The properties I would need would be pretty basic: Manager Name, Job Title (of both manager and employee) and Display Name. So something like:
Manager Name          Manager Job Title         Employee Name            Employee Job Title
Joe Smith                    CIO                 Jim Wilson                 VP of Widgets
Joe Smith                    CIO                 Robert Town                VP of Sparks
Jim Wilson              VP of Widgets            Mike Winger              Director of Widgets
Robert Town             VP of Sparks             Aaron Lewin               Director of Sparks
Here's the script that will do the job:
# Email message setings
$to = "%adm-InitiatorEmail%" # TODO: modify me
$htmlReportHeader = @"
<h1><b>Full List of Subordinates for %name%</b></h1><br/>
<table border="1">
    <tr>
        <th>Manager Name</th>
        <th>Manager Job Title</th>
        <th>Employee Name</th>
        <th>Employee Job Title</th>
    </tr>
"@ # TODO: modify me
$htmlReportFooter = @"
</table><br/>
<p><i>Please do not reply to this e-mail, it has been sent to you for notification purposes only.</i></p>
function GetAllSubordinates($directReportDN, $subordinates, $managerName, $managerJobTitle)
    if($subordinates.ContainsKey($directReportDN))
    # Bind to Subordinate
    $user = $Context.BindToObjectByDN($directReportDN)
    # Get user name
    $userName = $user.Get("name")
    # Get user job title
        $userJobTitle = $user.Get("title")
        $userJobTitle = " "
    # Add to HashTable
    $userInfo = New-Object PSObject
    $userInfo | add-member Noteproperty ManagerName $managerName
    $userInfo | add-member Noteproperty ManagerJobTitle $managerJobTitle
    $userInfo | add-member Noteproperty UserName $userName
    $userInfo | add-member Noteproperty UserJobTitle $userJobTitle
    $subordinates.Add($directReportDN, $userInfo) | Out-Null
    # Get Subordinates
        $directReportDNs = $user.GetEx("directReports")
    foreach ($directReportDN in $directReportDNs)
        GetAllSubordinates $directReportDN $subordinates $userName $userJobTitle
# Get subordinates
    $directReportDNs = $Context.TargetObject.GetEx("directReports")
    $Context.LogMessage("The user doesn't have any direct reports.", "Error") # TODO: modify me
$subordinates = New-Object "System.Collections.Hashtable"
    GetAllSubordinates $directReportDN $subordinates "%name%" "%title%"
# Sort list
$subordinates = $subordinates.Values | Sort-Object -Property @{Expression={$_.ManagerName}; Ascending=$True}
# Build HTML report
foreach ($subordinate in $subordinates)
    $htmlReportHeader += "<tr><td>" + $subordinate.ManagerName + "</td>"
    $htmlReportHeader += "<td>" + $subordinate.ManagerJobTitle + "</td>"
    $htmlReportHeader += "<td>" + $subordinate.UserName + "</td>"
    $htmlReportHeader += "<td>" + $subordinate.UserJobTitle + "</td></tr>"
$htmlBody = $htmlReportHeader + "</table>" + $htmlReportFooter
# Send the report
In the script:
  • $to - specifies the recipient of the email notification. The %adm-InitiatorEmail% that is used in the script will be replaced with the email address of the user who triggered execution of the script. For example, if the script is executed with the help of a Custom Command, it will be replaced with the email address of the user who launched the Custom Command.
  • $subject - specifies the subject of the email notification.
  • $htmlReportHeader - specifies the header of the email notification.
  • $htmlReportFooter - specifies the footer of the email notification.
Modify the script to your requirements.
To allow generating the report on demand with the help of a Custom Command:
  2. On the 2nd step of the Create Custom Command wizard, select the User object type.
  3. On the 3rd step, add the Run a program or PowerShell script action and paste the above script in the Script field.
by (360 points)
This is ridiculously awesome, and works perfectly. Thank you!
Thank you for your good words. We really appreciate it! :)
Microsoft supports decommissioning your last on prem Exchange Server and managing receipients using Windows PowerShell. See: https://learn.microsoft.com/en-us/exchange/manage- ... . Can the Exchange Management Tools be installed safely on an Adaxes Server?
asked 3 days ago by RayBilyk (310 points)
Hello I am looking fro information on managing custom attributes in Adaxes. I would like to create two custom attributes: Self Service Enrollment Stauts Object Type While ... " column above is not a slectable attribute for some reason. Software version:
asked Dec 10, 2025 by apruitt (450 points)
I was wondering if the abilities below are configurable for Domain Admin users in the web portal: Mass password reset Assign different passwords per person, so it's not the same ... to our users, instead of me writing a powershell script to do this. Thank you!
asked Jul 18, 2025 by apruitt (450 points)
What are the minimum security role requirements required for vieiwing management history within the Web GUI. I have granted the following to any authenticated users They are ... permissions should be required for allowing viewing this report in the Web GUI.
asked Feb 10, 2025 by KoleArmstrong (170 points)
asked Sep 18, 2024 by felix (210 points)
