I could use some help with a script. The script will need to do a couple of things.
1. Remove all special characters and spaces from %mobile% string, leaving a 10 digit phone number like 1234567890, and then add a 1 to the front for the US country code. I already have a regexp used as part of a property pattern that allows only the 10 digit phone number but allows for separators like parentheses, dashes, etc. The updated phone number with country code should be saved into %mobile%.
2. If custom text attrib #3 says no, the value provided in %mobile% should be moved to %otherMobile%, and then %mobile% should be cleared.
3. If custom text attrib #3 says yes, copy the %mobile% value into %othermobile%, but the %mobile% number stays where it is.
P.S. I know I could use a boolean attribute for the publish number field, but I've used up all the available boolean attributes and had lots of text attributes available, so I just used a property pattern to give a yes or no value option.
Thank You!
Ryan
by (920 points)
by (920 points)
On second thought...I don't think I can use %otherMobile% for SMS sending since it's a multi-value attribute. So instead of %otherMobile% can I use a custom text field or maybe integer?
Hello Ryan,
When you configure SMS settings for Adaxes service, you can also specify which property of user accounts will be used for storing their mobile numbers. The property that you specify will be used everywhere in Adaxes where sending of SMS messages is involved: sending of SMS messages with the help of the Send SMS operation, sending SMS messages from Business Rules and scripts, as well as sending SMS verification codes from Password Self-Service. For this purpose, you can use any property that allows soring string (text) values, including Adaxes virtual properties, such as CustomAttributeText1, for example. For information on how to select a property to be used for storing mobile numbers, see the 5th step in the following help article: http://www.adaxes.com/help/?HowDoI.Mana ... tings.html.
OK, we've asked our script guys to write a script for you.
Ryan,
Here's a script that meets your requirements. In the script, the mobile phone stored in the Mobile Phone property is copied to the CustomAttributeText8 property. If the CustomAttributeText3 property is not set to Yes, the Mobile Phone property is cleared.
Modify the following to meet your requirements:
  • $countryCode - specifies the country code,
  • $specialCharacters - specifies the special characters that need to be removed from the mobile phone.
$countryCode = 1 # TODO: modify me
$specialCharacters = @(" ", "-", "(", ")") # TODO: modify me
# Get mobile phone
    $mobilePhone = $Context.TargetObject.Get("mobile")
    $Context.LogMessage("Mobile phone is not specified", "Warning") # TODO: modify me
# Remove special characters
foreach ($character in $specialCharacters)
    $mobilePhone = $mobilePhone.Replace($character, "")
# Add country code to the mobile number
$mobilePhone = "$countryCode$mobilePhone"
# Update CustomAttributeText8
$Context.TargetObject.Put("adm-CustomAttributeText8", $mobilePhone)
# Get CustomAttributeText3
    $value = $Context.TargetObject.Get("adm-CustomAttributeText3")
    $value = $NULL
if ($value -ine "Yes")
    # Clear Mobile Phone property
    $Context.TargetObject.Put("mobile", $NULL)
# Save changes
by (920 points)
That's awesome! Thanks so much for the quick reply!
We would like to auto enroll our entire company into Adaxes for self service but do not want to use the question/answer format but instead their phone numbers (provided by HR department). Is this possible? Best, Evangelos
asked Oct 1, 2021 by evangelos (60 points)
Hello, i have a custom command which sets the oof-message for the selected user. in this custom command i have a parameter "param-vertretung" (ad-object picker). Now i want to ... and email of the stand-in in the oof-message. Can you help me with that? Thanks
asked Nov 13, 2020 by lohnag (160 points)
I have an issue with how phone numbers are rendered in the Web Interface. My Forms and Views configuration looks like this and when this is rendered in the web interface ... noting that in the other forms Create / modify, the property is handled as expected)
asked Apr 5, 2016 by sam.webster (410 points)
Hi, I have a lot of custom PowerShell scripts running and I am wondering, if its possible somehow to get the name of the PS Script the line of the execution of a code ... occurs and send directly the action, maybe path in Adaxes and line number of the script.
asked Oct 7, 2024 by wintec01 (2.6k points)
