Is there anyway to filter the approval request in the web interface?
We send automatic approvals for our computer deprovisioning and sometime there are hundreds of approvals waiting and the users want to be able to search on computer name to approve or decline the requests. This seems to be only available in the adaxes console , but we don't want to give those users access to the console.
Or is there a possibility to approve the requests by replying to the emails with scripting?
by (470 points)
Update 2018
Starting with Adaxes 2018.1 there is a filter option in Adaxes Web interface. The option is present on all the pages and can be used to filter out the information displayed including approval requests.
Original
Currently, this is not possible. However, for the next release, we are going to totally redesign the look and feel of Adaxes Web Interface. Among the new features, there will be the possibility to filter Approval Requests.
Hi, I was just wondering if there was a way to force the format of the date picker value in the web approval interface. We have operation that are very time specific ... like that in the web interface. Example of the problem: Thank you, Jean-Simon Tremblay
asked Dec 3, 2021 by jsimon.tremblay (20 points)
There seems to be a bug in the email being sent to approvers - the link for the selfservice portal is not reflecting the change in the IIS configuration - it still points ... the link to the selfservice portal they will get a 404 - File or Directory not found
asked Jul 4, 2018 by pafa (500 points)
Hallo, is it possible when a report is generated that the column values can be Filtered and it show the Fliterd Reports? The Report that i what to use is Users' membership in groups and the Column to Filter is the "Parent". Thank you for your help
asked May 31, 2022 by Sandberg94 (340 points)
I'm currently using a couple extension attributes to define custom fields, such as Community, Team and Branch. I currently have a defined list of Departments (LDAP attribute " ... possible" that I can take back to the Project manager. Thanks in advance! Dan
asked Jul 31, 2012 by Dbradford (170 points)
In the Adaxes web interface configuratior, you can set up custom actions, and adjust the object selector. I am able to set Object Selection to "Objects selected by user," and ... this question makes sense. Please let me know if there's anything I can clarify.
asked Nov 25, 2025 by apruitt (490 points)
