We have 3 Adaxes services (in 2014.1) and we would like specify 3 different "Web Interface Address". One by Adaxes Service.
When I change this parameter for one service, it's modified for each. Is it then desired beahavior ?
Thanks in advance
Regards,
Sebastien
by (740 points)
Hello Sebastien,
Yes, this is by design. If the services share common configuration, the Web Interface address is also replicated among them.
OK.
I tried to clear web interface service address and to add a link to the correct web page by editing "Submitted" notification.
It seems that it's synced too.
Have you any idea ? The fact is that could be very slow depending on where are located approvers.
regards
For example, you can achieve this by configuring your DNS. As fas as we understand, your users are scattered across multiple sites, and the slow connections between them make the Web interface slow if users get connected to a Web interface located not in their own site. In such a case, you can configure the DNS servers in the different sites so that the Web Interface address would be resolved into different IPs depending on which site a user comes from. Thus, in each site, the Web interface address needs to be resolved into the IP of the 'local' Web interface.
That's, probably, the only option we can come up with.
Hi Is it possible to get the Web Interface address via a script? Thanks Matt
asked Oct 13, 2023 by chappers77 (2.0k points)
Hi We have Adaxes available through Azure app proxy as we have external support for some of our companies and these people don't have VPN available to them. The ... change the Web Interface Address to the Azure link? Will this break anything? Thanks Matt
asked Jan 20, 2022 by chappers77 (2.0k points)
I am evaluating Adaxes. I noticed that the web interface does not allow modification of the External Email Address (ms-Exch-Target-Address). What would someone do if they needed to change the Target Address?
We would like users to be able to add their mobile number and carrier information from within the web console. Preferably, they would enter their mobile number in a ... ". This address would then be written to an extensionAttribute field in Active Directory.
asked Mar 2, 2016 by Kikaida (1.1k points)
I am doing a proof of concept deployment of Adaxes and I am struggling with something that I believe is easy to correct. I am using the web form to create a new user with a space in it's name ... zA-Z0-9-]+.)+[a-zA-Z0-9_-]+$'." What did I miss for this config?
asked Jul 22, 2021 by jwisniewski (20 points)
3,737 questions
8,637 comments
550,335 users
