Maybe i'm doing something wrong but i have an issue with permission inheritance :
I have a role (Helpdesk) that gives some users rights to manage Business Units content and to see Business Units objects (in order to get them in Web UI).
I use local security groups for that and it works every scope except BU object.
In order to see BU in Web UI, i have to add explicitely the user account over the BU object.
It happens only for BU objects.
Strange, isn't it ?
by (800 points)
Permissions to a local security group can be granted only to AD objects located in the domain of this group. The security role doesn't work because Business Units are not located in your AD domain.
We will investigate how to overcome this restriction, and in the next version it will be possible to grant permissions to local security groups over Business Units and objects from other AD domains.
Thank you for the cooperation!
by (800 points)
Thanks for the explanation.
Sorry to ask, but do have any information about the next release date ?
The next version is scheduled for release in September - October.
I'm having trouble with permissions regarding creating a new user. I created a security role for HR and when they try to create a new user and are prompted for a ... Web Interface, because I just tried it with the Superuser account and it is still blank.
asked Oct 9, 2024 by jmatthews (250 points)
Hello, We create home folders using custom command: Service account to perform operations within the domain has: a) domain admin rights b) server admin rights On the ... user as the directory owner, however the user was granted the Take Ownership permission.
asked Mar 15, 2023 by juhota (230 points)
I know the question is related to an older version, but where do I find the "Thumbnail Photo Part" in Permissions? The task is: A department should be able to change the Userpicture, nothing else. Thanks
asked Nov 24, 2022 by boris (570 points)
