Dear Support, hope you are well during this pandemic!
Can you please if it's possible to use different urls for different interfaces and how it can be set up? E.g. I have 2 interfaces Team1 and Team2 on my server server-adaxes.com, I've created CNAME entries in DNS to point to same ip and I want to use:
  • adaxes-L1. com for Team1 interface
  • adaxes-L2. com for Team2 interface
Thanks for help!
by (920 points)
Hello Dmytro,
Unfortunately, there is no possibility to configure such redirection via DNS settings.
Specific Web Interfaces can be accessed directly using URLs like the following: http://host.company.com/Adaxes/HelpDesk. In your case, the URLs should be http://server-adaxes.com/Adaxes/Team1 for Team1 and http://server-adaxes.com/Adaxes/Team2 for Team2. If necessary, the Adaxes part can be removed from Web Interface URLs. For details, see https://www.adaxes.com/questions/8940/can-i-remove-the-adaxes-part-from-web-interface-urls. In the URLs, the actual names (NOT display names) of the Web Interfaces must be used. To check the name of a Web Interface:
  2. Expand the drop-down menu in the top left corner and click Manage Configurations. image.png
  3. Select the Web Interface whose name you need to check and click Rename. image.png
by (920 points)
And if I have 2 adaxes servers can they have different URLs like mentioned?
Dmytro,
Yes, Web Interfaces on different servers can be accessed using different URLs. To make accessible only specific Web Interfaces on a web server, you need to disable the rest of Web Interfaces on the server. For information on how to disable a Web Interface on specific web servers, please, have a look at the following tutorial: https://www.adaxes.com/tutorials_WebInterfaceCustomization_DisableWebInterfaceOnWebServers.htm.
by (920 points)
Hello, I followed you recomendations and left only 1 interface on the server, but I still cannot access it over separate URL - HTTP Error 404. The requested resource is not found. I've tried https://url/Team2, https://url/Adaxes/Team2, same error :(
Hello Dmytro,
The error is not caused by Adaxes settings. It is returned by IIS. For troubleshooting purposes, please, do the following on each server where your Adaxes Web Interface does not work:
  1. Launch Internet Information Services (IIS) Manager.
  2. In the Connections pane, expand the server that hosts Adaxes Web Interface and then expand Sites.
  3. Expand the web site that hosts Adaxes Web Interface.
  4. Right-click the Adaxes virtual directory.
  5. In the context menu, navigate to Manage Application and click Browse. image.png
  6. Does the page load successfully? If you get a different error message, please, post it here or send to our Support Team (support[at]adaxes.com).
by (60 points)
Hi so if I have the web-interface setup on my internal server where I did the full install but I also have setup a RODC in DMZ how can I "merge" so that the URLS given are for the one in the DMZ vs internal. I have noticed that for example I can have a user manually go to the External one with the DMZ/Public facing IP but I can't seem to get the offline/unlock that shows up to link and show/work for the web server on the DMZ
Unfortunately, there is no functionality in Adaxes for manipulating URLs. It can only be done in IIS. However, it looks like the only option in your case is to use a load balancer that will forward users to the correct URL.
Hi there, I am just wondering if it is possible to change the URL slug of the web interface URL's. For example, when browsing to a user, the slug is: https://adaxes. ... object ID to not expose this kind of information. Is there a way to achieve this? Thanks.
asked Mar 29, 2022 by bjorn19 (20 points)
I need a report that will show what O365 Licenses each user has based on Office. If can emailed or with in reports
asked Jan 17, 2020 by hgletifer (1.3k points)
I have a network with 2 forests, the Main forest we have no issues with AD and Exchange. how ever the second forest AD is good we see exchange properties in Adaxes ... able to have two forests with an exchange server for each forest operational in Adaxes? Tony
asked Feb 20, 2015 by babbeaw (320 points)
I am running the web interface on a separate server from the Adaxes Service and all 3 directories (admin, helpdesk, selfservice) are currently install in a single IIS site ... 's, given that I am intending to split the web interface across multiple websites?
asked Apr 27, 2017 by HDClown (220 points)
asked Sep 7 by lbressan (160 points)
