Our users accounts are on-prem & synched through DirSync. Our distribution groups are cloud based only.
What's the best way to automatically to accomplish these task?
1. Add newly created users to the appropraite cloud based distribution groups automatically. ("All employee's" for example)
2. Dynamically add any existing users in a specific OU to a specific group on a set schedule? (to enforce the list being up to date if an account is created outside of adaxes)
by (340 points)
When setting up a rule based group, GMSA objects are not visible. Is there a setting or view I need to add to make these availabe to rule based groups, or is it simply not an option?
asked Sep 16, 2024 by ajmilic (150 points)
When I create a user from adaxes I also want it to be added to MS Teams groups. At this moment i create the account in adaxes after that i need to add this user in all groups that we have in MS Teams so i what to automate this when i create a new usuer.
asked Mar 29, 2022 by abisaigomezm (40 points)
We are working with an HR package that will send us a CSV file every 4 hours with a list of users that need to be created, modified or deleted from our environment. The CSV ... change, etc.) Is there a script that can manage all of that on a scheduled basis?
asked Sep 2, 2020 by RayBilyk (310 points)
