Hi The Custom Commands edil Box Send more symbols. If type the symbols $ the will output '$ How can I fix it? Input image.png Output image.png
by (90 points)
Hello Will,
Please, describe the workflow you have in all the possible details with live examples and screenshots. Please, specify how and where exactly you make the input and the output.
Hello Will,
Unfortunately, we were not able to reproduce the behaviour you are facing. Please, send us (support@adaxes.com) the full script you are using in TXT format.
Also, please, specify your Adaxes version. For information on how to check it, see https://www.adaxes.com/help/CheckServiceVersion.
Hello Will,
Thank you for the provided details. The behaviour is by design for cases when value references are wrapped into single quotes. To achieve the desired, replace all single quotes in your script with double ones. Also, for you information, value references should always be wrapped into double quotes in all Adaxes scripts.
I need to add many check-box list items to a Custom Command, I think the best way to do this is via PowerShell rather than through the UI. What's ... Softerra.Adaxes.Interop.Adsi.Parameters.IAdmParameterCheck[]]$ItemsList # Also doesn't work $command.SetInfo()
asked Jan 4 by Viajaz (210 points)
Whilst the Web UI's Custom Forms and Views for each Object Type is useful, it's also very limiting presentation-wise if we want different users, computers, ... user groups and ensure a tidier experience whilst enforcing ACLs on various attributes and objects.
asked Feb 5 by Renugopal (120 points)
Hi. I am create a Custom Commands. The Custom Commands will run a powshell by user. Is it possible for me to require the user to verify the passwordagain when performing these Custom Commands?
asked May 20, 2022 by will.chc.join (90 points)
For a custom command, I need to perform some actions, then reboot a computer, then perform some more. How can we handle the reboot so the actions continue once the computer is back up and ready? Thanks
asked May 17, 2022 by jcrook (100 points)
3,346 questions
7,782 comments
544,984 users
