Hi all,
I setup some rule-based groups and tried to copy criterias from group A to B. I did it via "copy" and "copy as plain text" option, but everytime pasting is failing : (
by (1.1k points)
by (273k points)
It is only possible to copy/paste criteria when HTTPS is enabled for Adaxes Web interface. You can configure SSL on the Adaxes Web interface the way you do it for any other website hosted by IIS. For details on how to enable SSL for an IIS Web Site, see the following article: https://docs.microsoft.com/en-us/troubleshoot/iis/enable-ssl-all-customers.
SSL is already enabled, but we use a reverse proxy at the moment and load balancing traffic. Will check our setup again - or do you have any recommendations?
As per our check, there is nothing else but SSL that can influence copying criteria in Adaxes Web interface. Unfortunately, the only thing about your setup we recommend is checking the documentation for your reverse proxy. There can be some checkbox that needs to be selected or something like that.
I'm trying to combine these two scripts to effectively store a user's group memberships in customattributebinary5 and then be able to copy and paste those memberships to a ... ) $Context.LogMessage("Added the user to group '$groupName'", "Information") }
asked Jan 24, 2020 by yourpp (540 points)
With Active Directory Users and Computers, I can add group members by copying a list of usernames and pasting them into the Add Members dialog box. This is very quick and easy. How can I do this with Adaxes? It seems that I can only add one member at a time.
asked Feb 24, 2017 by abarker5 (80 points)
Hi, In the previous version of Adaxes <2018 we could right click and copy/paste a form from one interface to the other. Since the 2018 version with the web console we ... ve selected. :? So how do I copy/paste a specific action form another web interface?
asked May 17, 2019 by alex-df (440 points)
On the Home page Action screen(Configure Home Page Actions), there are groups and actions under those groups. In the new version there is a COPY command if you right click( ... copied...but nothing ever gets pasted. Bug or am I doing something wrong. Thanks!
asked Jun 18, 2012 by mpaul (360 points)
I'm building my first rule to license users in Office365. When the rule runs it fails to find the Usage Location which is based on the Country (default settings). I ... runs before the "assign 365 license" rule. Why am I not getting Usage Location populated?
asked Jul 20, 2020 by ComputerHabit (790 points)
545,374 users
