I am testing using MFA and we use Duo. I havn't seen where we can set up push instead of adding having the end users set up another account for Duo.
by (1.0k points)
Unfortunately, there is no possibility to use Duo Push or an existing Duo app account for authentication in Adaxes Web interface.
We are trying to avoid the issue of deleting accounts and resting accounts, we want to implement disconnecting the account by setting the immutable id to null on accounts we want to keep.
asked Aug 16, 2023 by Carlos (20 points)
Is there a way to run this report against Exchange Online instead of a local Exchange server?
asked Jul 13, 2022 by RayBilyk (230 points)
Here we use BambooHR but we only have the conection thrue a group in AD with SML in BambooHR, so can we have a conection way thrue ADAXES to change setings, Examle Manager, Departament etc...
asked Jun 7, 2022 by abisaigomezm (40 points)
is it possible to allow a user to enroll for both options, or even only one option out of the two available? I would like to give my users the choice to use either. Some users may not want an authenticator, but other's might do.
asked Nov 6, 2019 by mashworth (80 points)
Like remove all users from full access other than User1, User 2, & User3?
asked Oct 29, 2019 by hgletifer (1.3k points)
3,355 questions
7,799 comments
545,153 users
