Like remove all users from full access other than User1, User 2, & User3?
related to an answer for: Delegation removal
by (1.3k points)
This can be done using a PowerShell script. The users to skip can be predefined in the script or specified using a parameter if the script will be executed in a Custom Command. Please, specify which approach meets your needs and we will provide you with detailed instructions.
Great, I think prededefined groups and users not to remove would be best for us.
Thank you for the confirmation. Have a look at the following script from our repository: https://www.adaxes.com/script-repository/remove-all-trustees-from-full-access-list-s559.htm.
We have users with group memberships in multiple domain. All groups are type Universal. For example we have DOMAIN A and child domains for each dept, such as ... group memberships during user account copy, including memberships from other domains? Thank you,
asked Sep 10, 2020 by maliguinem (20 points)
If I have created an custom command i would like to find where this CC is used (linked) in Adaxes (used in Scheduked Task and so on). How can a general find references ... report where I can find all the Linked Objects that I have created by myself in Adaxes ?
asked Jun 1, 2023 by Beat Ott (40 points)
When I create a user from adaxes I also want it to be added to MS Teams groups. At this moment i create the account in adaxes after that i need to add this user in all groups that we have in MS Teams so i what to automate this when i create a new usuer.
asked Mar 29, 2022 by abisaigomezm (40 points)
7,805 comments
545,196 users
