How can we make sure that only the allowed users can login to the web UI?
We are planning to have two instances of Adaxes web UI. The first one should allow our internal users and helpdesk only. The other one should be accessible for people from other offices (for self-service).
by (70 points)
Update 2018
Starting with Adaxes version 2018.1 Web interface access is controlled in the Web interface configurator. For details, have a look at the following tutorial: https://www.adaxes.com/tutorials_WebInterfaceCustomization_AllowDenyAccessToTheWebInterface.htm.
Original
In the Web.config file that is located in the C:\Program Files\Softerra\Adaxes 2\Web Interface folder, specify the users you need in the <authorization> element:
    <authorization>
      <allow users="username1@domain.com,username2@domain.com" />
      <deny users="*" />
    </authorization>
At the moment it is possible to allow or deny specific users (not groups) to connect to Adaxes Web Interface. In the next version (2011.1) it will be also possible to specify groups.
We've released Adaxes 2011.1. This version enables you to allow or deny specific users or groups to access the Web Interface. For more details, see Allow/Deny Access to the Web Interface.
What I'm trying to accomplish: user should have access to modify certain accounts where customTextAttribute2="test" (example). When I modify the criteria under "object selection" ... to query custom attributes or do you have to use AD attributes for this?
asked Mar 19 by tromanko (180 points)
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8 by Handernye (50 points)
As you can see in the picture, we currently have three different formats as soon as we look at a user's data. Can this be adjusted so that only one format dd.mm.yyyy is displayed? Thank you very much
asked Nov 17, 2023 by DRiVSSi (280 points)
7,802 comments
545,175 users
