Hello All,
I'm trying to install demo of product on Windows Server 2008 R2 64. When I open web interface none of my graphics are showing and the page is not properly formatted.
by (70 points)
What Internet browser do you use? Also please post a screenshot of the Web Interface.
I/we use IE8.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3)
Timestamp: Mon, 21 Feb 2011 13:42:25 UTC
Message: Object expected
Line: 5
Char: 32749
Code: 0
URI: http://rhcadaxes01.r.local/Adaxes/Scrip ... t=5c2f384e
Please make sure you have the Static Content feature installed for IIS.
Worked! Thanks
What I'm trying to accomplish: user should have access to modify certain accounts where customTextAttribute2="test" (example). When I modify the criteria under "object selection" ... to query custom attributes or do you have to use AD attributes for this?
asked Mar 19 by tromanko (180 points)
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8 by Handernye (50 points)
As you can see in the picture, we currently have three different formats as soon as we look at a user's data. Can this be adjusted so that only one format dd.mm.yyyy is displayed? Thank you very much
asked Nov 17, 2023 by DRiVSSi (280 points)
3,365 questions
545,268 users
