I try to run following powershell code from Script Repository "Add users to group in bulk". I always get the message "User TestUser1 was not found".
We use Adaxes to manage more then 10 domains. I think the problematic line is with the Get-AdmUser command. When I remove "-AdaxesService localhost", script runs well in the domain where Adaxes server resides. Or if I specify an "Run as" account from the domain where the group resides - users were added to the group. But Custom Command should run in every Managed Domain with the configured Service Account.
regards Helmut
by (510 points)
This is exactly how the script is designed to work. It only searches for users in the domain where the group is located. Also, when you remove the -AdaxesService parameter for the Get-AdmUser cmdlet, the search is performed in AD avoiding Adaxes. In this case, users that are in the Adaxes unmanaged list can also be added to the group. We will update the script to add group members independently of their domain. Once the script is ready, we will get back to you right away.
We updated the script to meet your needs. You can copy it here.
by (510 points)
thanks for updating script to our meets. I have an additional question: because our admin accounts are named in all manged Domain the same we get the message "Found more then one account..." How can we change the filter to search only in domain where the group resides?
regards Helmut
Hello Helmut,
It cannot be done by only updating the search filter. It is required to change the search base. Below is the version of the script that will perform the search only in the domain of the target group.
$propertyForUsernames = "adm-CustomAttributeText1" #TODO: modify me
function SearchObjects($filter)
    $searcher = $Context.BindToObjectByDN("%adm-DomainDN%")
    $searcher.SizeLimit = 2
        # Execute search
        return ,$searchResults
        # Release resources
# Get usernames from the custom attribute
    $sAMAccountNames = ($Context.TargetObject.Get($propertyForUsernames)).Split(",")
# Get the current group members
    $memberGuidsBytes = $Context.TargetObject.GetEx("adm-DirectMembersGuid")
    $memberGuidsBytes = @()
$memberGuids = New-Object "System.Collections.Generic.HashSet[System.Guid]"
$memberGuidsBytes | %%{ $memberGuids.Add([Guid]$_) }
foreach ($sAMAccountName in $sAMAccountNames)
    $searchResults = SearchObjects "(sAMAccountName=$sAMAccountName)"
        $Context.LogMessage("Account with username $sAMAccountName not found.", "Warning")
    elseif ($searchResults.Length -gt 1)
        $Context.LogMessage("Found more than one account with username $sAMAccountName", "Warning")
    # Add the user to the group
    $userGuid = [Guid]$searchResults[0].Properties["objectGUID"].Value
    if (-not($memberGuids.Contains($userGuid)))
            $Context.TargetObject.Add("Adaxes://<GUID=$userGuid>")
            $Context.LogMessage("An error occurred when addingaccount with username $sAMAccountName to the group. Error: " + $_.Exception.Message, "Warning") # TODO: modify me
        $Context.LogMessage("User $sAMAccountName is already a member of the group.", "Information") # TODO: modify me
# Clear custom attribute
$Context.TargetObject.Put($propertyForUsernames, $NULL)
$Context.TargetObject.SetInfoEx(@($propertyForUsernames))
asked Jul 1, 2025 by srisingerOMF (20 points)
We have a Hybrid enviroment where our On-Prem AD is leading. We also have cloud only groups. Now I need to give key users rights to manage the memebership of the cloud ... cannot select the On-Prem domain. The option is greyed out. Am I missing something?
asked Jan 30, 2024 by a.blonk (200 points)
Hi All, I was following the following documentation https://www.adaxes.com/tutorials_DelegatingPermissions_GrantRightsToModifyADGroupMembership.htm However I cannot work out how to make it ... can only add themselves. Any help would be great. Many Thanks
asked Mar 30, 2020 by antondubek (440 points)
