by (50 points)
What exactly do you mean by MFA here?
by (50 points)
Users enrolled in any multifactor authentication policy within Adaxes.
I want a script to query MFA enrollment status, then add only enrolled users to an AD group.
Here is a script I found that should generate a CSV file with all user enrollment status, however it does not run either within Adaxes as a custom scheduled task as an action of type "Run a program or PowerShell script" or via PowerShell directly. Email functionality in the script is ignored as I'm only trying to write a CSV. The errors will be posted below the script.
Script:
$ouDNs = @("CN=Users,DC=domain,DC=com", "DC=domain,DC=com") # TODO modify me. Set to @() for search all users
$reportType = "Enrolled" # TODO: uncomment the type you need
# $reportType = "Not enrolled"
# $reportType = $NULL
# CSV file settings
$csvFilePath = "C:\tools\enrollment-report.csv" # TODO: modify me
$removeCSVFile = $False # TODO: modify me
# Mail settings
$from = "noreply@localhost" # TODO: modify me
$smtpServer = "mailserver.domain.com" # TODO: modify me
$subject = "Password Self-Service statistics" # TODO: modify me
$message = "Password Self-Service statistics" # TODO: modify me
function GetUserGuids($dn, $list)
    $searcher = $Context.BindToObjectByDN($dn)
    $searcher.Criteria = New-AdmCriteria "user"
    $searcher.SetPropertiesToLoad(@("objectGUID"))
        $searchResults | %%{[void]$list.Add([Guid]$_.Properties["objectGUID"].Value)}
        # Release resources
# Bind to the 'Password Self-Service Statistics' container
$passwordSelfServiceStatisticsPath = $Context.GetWellKnownContainerPath("PasswordSelfServiceStatistics")
$passwordSelfServiceStatistics = $Context.BindToObject($passwordSelfServiceStatisticsPath)
# Get the enrollment report
$reportIsBeingGenerated = $True
do
        $report = $passwordSelfServiceStatistics.GetReport("ADM_PSSREPORTTYPE_ENROLLMENT")
    catch [System.Runtime.InteropServices.COMException]
        if ($_.Exception.ErrorCode -eq "-2147024875")
            # Report is being generated. Wait 10 seconds
            Start-Sleep -Seconds 10
            $reportIsBeingGenerated = $False
    if ($report.GenerateDate -lt [System.Datetime]::UtcNow.AddHours(-1))
        $passwordSelfServiceStatistics.ResetReportCache("ADM_PSSREPORTTYPE_ENROLLMENT")
while ($reportIsBeingGenerated)
# Get user guids
$userGuids = New-Object "System.Collections.Generic.HashSet[System.Guid]"
foreach ($dn in $ouDNs)
    GetUserGuids $dn $userGuids
# Build the report
$reportRecords = New-Object System.Collections.ArrayList
$records = $report.Records
for ($i = 0; $i -lt $records.Count; $i++)
    $record = $records.GetRecord($i)
    # Get user information
    $userPath = $NULL
    $userDisplayName = $NULL
    $userParentCanonicalName = $NULL
    $userAccountIsEnabled = $NULL
    $userIsEnrolled = $NULL
    $userAccountIsExpired = $NULL
    $userInfo = $record.GetUserInfo([ref]$userPath, [ref]$userDisplayName, [ref]$userParentCanonicalName,
        [ref]$userAccountIsEnabled, [ref]$userIsEnrolled, [ref]$userAccountIsExpired)
    $path = New-Object Softerra.Adaxes.Adsi.AdsPath $userPath
    $guid = [Guid]$path.Guid
    if ($userGuids.Count -ne 0 -and !$userGuids.Contains($guid))
    if (($reportType -eq "Enrolled" -and !$userIsEnrolled) -or
        ($reportType -eq "Not enrolled" -and $userIsEnrolled))
    # Get event date
    $eventDate = $record.EventDate
    if ($eventDate -eq [DateTime]::MinValue)
        $eventDate = $NULL
    # Get policy information
    $policyPath = $NULL
    $policyName = $NULL
    $policyInfo = $record.GetEnrollmentPolicyInfo([ref]$policyPath, [ref]$policyName)
    if ($userIsEnrolled)
        $userIsEnrolled = "Yes ($policyName)"
        $userIsEnrolled = "No"
    # Get invitation info
    $successSendDate = New-Object System.Datetime 0
    $errorMessage = $NULL
    $record.GetSendInvitationInfo([ref]$successSendDate, [ref]$errorMessage)
    if ([System.String]::IsNullOrEmpty($errorMessage) -and $successSendDate -ne [Datetime]::MinValue)
        $enrollmentInvitation = $successSendDate
        $enrollmentInvitation = $errorMessage
    # Get effective policy information
    $effectivePolicyPath = $NULL
    $effectivePolicyName = $NULL
    $record.GetEffectivePolicyInfo([ref]$effectivePolicyPath, [ref]$effectivePolicyName)
    # Add information to the report
    $reportRecord = [PSCustomObject][ordered]@{
        "Name" = $userDisplayName
        "Parent" = $userParentCanonicalName
        "Enrolled" = $userIsEnrolled
        "Effective Policy" = $effectivePolicyName
        "Date/Time" = $eventDate
        "Enrollment Invitation" = $enrollmentInvitation
    $reportRecords.Add($reportRecord)
# Export to CSV
$reportRecords | Sort-Object @sortParameters | Export-csv -NoTypeInformation -Path $csvFilePath
# Send mail
#Send-MailMessage -To $to -from $from -SmtpServer $smtpServer -Subject $subject -Body $message -Attachments $csvFilePath
if ($removeCSVFile)
    # Remove temporary file
    Remove-Item $csvFilePath -Force
Errors running within Adaxes:
    The term 'New-AdmCriteria' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again. Stack trace: at GetUserGuids, <No file>: line 21 at <ScriptBlock>, <No file>: line 83
    Exception calling "ExecuteSearch" with "0" argument(s): "Search filter is not specified. Parameter name: searchParameters" Stack trace: at GetUserGuids, <No file>: line 28 at <ScriptBlock>, <No file>: line 83
Do you mean accounts enrolled to use mobile applications either for Web interface sign in or password self-service?
It looks like you are using a version of Adaxes older than 2023. The cmdlet is not available in this case and the error is expected. For details on how to check your Adaxes service version, see https://www.adaxes.com/help/CheckServiceVersion.
by (50 points)
Yes, MFA for password self service or web interface sign in. Primarly to be used for external facing password self service.
Yes we're running 2021.1 (3.14.21404.0), because we've been working through issues managing all of our customer domains when we attempt to upgrade to 2023.2.
This MFA script task needs to be completed on the current 2021.1 version because we still do not have the unrelated upgrade issue resolved.
Thank you for the provided details. How exactly do you want the script to work? Should it add all enrolled users from a predefined location? Should there be any other filters applied to the users?
by (50 points)
We would like the script to add MFA enrolled users to a specific AD group. Ideally, we'll empty the group when this enrollment script runs periodically just in case someone gets unenrolled for some reason.
Thank you for specifying. You can use a scheduled task like below. For details on creating scheduled tasks, have a look at the following tutorial: https://www.adaxes.com/help/ScheduleTasksForDirectoryManagement. image.png In the task:
The user is enrolled for TOTP
$applications = $Context.TargetObject.GetApplicationsUserEnrolledIn()
$Context.ConditionIsMet = $applications.Length -ne 0
The user is NOT enrolled for TOTP
$Context.ConditionIsMet = $applications.Length -eq 0
asked Jul 1, 2025 by srisingerOMF (20 points)
Is there a report which shows users who are not a member of a specific group?
asked May 3, 2023 by dgilmour (20 points)
Hello, I have my OUs structured so each department we're working with has an OU for their service accounts under their department OU. e.g. OU=Service Accounts,OU=Sales,OU= ... add each new OU to the scheduled task but I was hoping for something more hands off.
asked Oct 19, 2015 by drew.tittle (810 points)
asked Jan 27, 2023 by samuel.anim-addo (20 points)
