Ref: http://www.adaxes.com/info_whats-new_2012.1.htm
How do I disable this option in these situations:
- "Please select new members"
- "Please select groups"
- Thanks in advance
by (2.6k points)
If you see the link when executing an action from the home page, you can configure the action to display the list of objects right away:
  1. Open the properties of the Home Page Action you need. For details, see Step 6 of the following tutorial: http://www.adaxes.com/tutorials_WebInte ... ctions.htm.
  2. Activate the Target Object Selection tab.
  3. Disable the Do not display available objects automatically option.
As for the Members and Members Of sections, there is no way to get rid of this link. However, if you enter some search text in the Search field, the search will start immediately when you press the Enter key. We will think on how to improve this behavior in the next major version of Adaxes.
I've given a group of users permissions to the logging reports. They can review the logs but when clicking on an item they get Access Denied. What permissions do I need to give the group to be able to read the logs?
asked Jul 20, 2020 by ComputerHabit (810 points)
asked Dec 12, 2024 by msheppard (840 points)
Users are asking if they can change their name to suit preferred names as opposed to birth names? Is this possible?
asked Oct 14, 2024 by Charlie.Evans (70 points)
I am using an account with global admin permissions to o365, so it does not appear to be that as the issue. Adaxes V.2017.2 Trace logs showing the following [11/02/2022 11:24:58] ... at #2e.#Vh.#h8() at #eb.#Wb.#j8() at #2e.#Uh.Execute(#ib command) Any ideas?
asked Nov 2, 2022 by bbrunning (50 points)
550,365 users
