Hello
I'm in the process of moving both the Self Service and the Help Desk Pages from one webserver to another.
I have a backed up copy of the interface configuration copied to the webserver.
I installed the web pages for Self Service and Help Desk on the new web server.
When I go into the Web interface configuration tool and go to restore configuration it gets to the progress report page and on both pages I get an error for each saying "Object AdaxesHelpDesk Already Exists" "Object AdaxesSelfService Already Exists"
I checked the FAQ here: http://www.adaxes.com/help/?HowDoI.Conf ... onfig.html
I did a little searching for the error and I'm coming up with nothing helpful.
Any ideas?
by (810 points)
by (810 points)
I figured out what the problem was.
I changed the virtual directory on the new install to "HelpDesk and SelfService" from "AdaxesHelpdesk and AdaxesSelfService". Deploying back to the renamed virtual directory was failing.
I can change the Virtual Directory and Alias after the restore but I'm left wondering if that's such a good idea...
Is there a supported way to change the alias/Virtual Directory on a new install and apply the backup of the ui config to it?
by (810 points)
So I can get around the error but I seem to be unable to get my configuration backup to restore with a virtual directory other than Adaxes...
Is it possible to make that happen or am I stuck changing the vDir and Alias after the restore?
Can you send your Web interface backup file to our support email(support[at]adaxes.com)?
Hello, I am not getting email responses from support because of a technical problem. In the meantime, I figured for I would post here. I am using the new heldesk web ... how the helpdesk interface is configured and what the user's screen looks like: Thanks.
asked Jul 20, 2018 by Jasonmh (540 points)
I'm trying to provide the capability for ID admin users to perform AD tasks using the web interface. I am not able to edit attributes for an existing user when ... any attribute it gives me an error "An unexpected response was received from the server".
asked Apr 8, 2021 by atnorman (120 points)
Hello, I get this error after logging into the web interface (As Adaxes Admin):   Fatal Error - Cannot process the request because the request signature is invalid or ... Adaxes Services/Server about 3 or 4 times now and restarting the computer as well.
asked Feb 6, 2023 by Edogstraus00 (590 points)
Hello, after upgrading to Adaxes 2023 we lost connection to Web Interface Configurator. Adaxes and Adaxes Web Interface are ok and users are able to login. URL http: ... went ok except I had to start manually Softerrra Adaxes service after restoring settings.
asked Nov 28, 2022 by juhota (230 points)
