i have an powerhell variable that contains a hashtable. Is there a way to add the content of this hashtable to an adm-CustomAttributeTextMultiValue of a user?
I tried the following, but it's not working:
Set-ADmUser -identity $sam -add @{"adm-CustomAttributeTextMultiValue1"=$hashtable} -AdaxesService localhost
Thanks for your assistance!
by (170 points)
by (307k points)
Unfortunately, it cannot work like that as each value of a multi-valued attribute must be a string. Could you, please, provide us with an example of the hash table you have and how exactly you need to save values to adm-CustomAttributeTextMultiValue1?
Also, please, specify where the script will be executed (e.g. in a custom command, outside of Adaxes, etc.).
by (170 points)
i would like to use it in a custom command.
The hash table looks somehow like this:
Name                           Value
UserPrincipalName              user@domain.com
TwoWayVoiceMobile              False
DisplayName                    User, Name
PhoneAppNotificationIsDefault  True
PhoneAppOTP                    False
AuthPhoneNumber                +49 160 1234567
AuthAltPhone
AuthEmail
PhoneAppOTPIsDefault           False
PhoneDeviceName                {iPhone, iPhone}
ObjectID                       as04654-sdd-e104-0815-4711
PhoneAppNotification           True
State                          Disabled
TwoWayVoiceMobileIsDefault     False
OneWaySMSIsDefault             False
OneWaySMS                      True
It would be nice to have it in the CustomAttributeTextMultiValue1 row per row with Name: Value., i.E.:
UserPrincipalName:  user@domain.com
TwoWayVoiceMobile:  False
DisplayName: User, Name
Thanks a lot
by (307k points)
Thank you for the provided details. For us to help you with a solution, please, provide the full script you are using in TXT format.
by (307k points)
In case if you have a general hash table (e.g. specified in a script variable), you can use the below script to save the key-value pair from the table into an Adaxes custom multi-valued attribute.
$hashTable = @{
    "key1" = "value1";
    "key2" = "value2";
    "key3" = "value3";
# Convert hash table into array
$array = $hashTable.GetEnumerator() | %% {"$($_.Key): $($_.Value)"}
# Update the target user
$Context.TargetObject.PutEx("ADS_PROPERTY_UPDATE", "adm-CustomAttributeTextMultiValue1", $array)
Dear Can I use more than ten adm-CustomAttributeTextMultiValue in Adaxes? Sincerly
asked Jun 29, 2020 by hilmiemrebayat (120 points)
Hi We need to generate random employee numbers for test accounts, but these need to be between 80000 & 90000 to ensure they are identified as test. Is it possible to do this using just the %adm-RandomInteger% value reference? Thanks Matt
asked Mar 8, 2022 by chappers77 (2.0k points)
I have seen object Adaxes variables such as adm-DirectMemberOfGuid and adm-O365ObjectId. Are these adx- variables listed in documentation somewhere? I could not find them in the Adaxes SDK documentation.
asked Dec 12, 2022 by Viajaz (210 points)
asked Oct 6 by DRiVSSi (360 points)
