Dear
Can I use more than ten adm-CustomAttributeTextMultiValue in Adaxes?
Sincerly
by (120 points)
by (16.9k points)
Unfortunately, there is no such possibility. We will consider a possibility to increase the number of custom multivalued text attributes in one of the future releases. Meanwhile, could you, please, describe the workflow that requires more than 10 custom multivalued text attributes so we could try to propose a workaround?
by (120 points)
Dear
Now, we have have 12 schools. Each school has his own name of classes. When we are making a user, we must select which user gives lesseon in which class.
I'm adding the classes to the adm-CustomAttributeTextMultiValue with the Sheduler on Adaxes. The sheduler takes the classes from the groups that are in a specific OU in the AD. Each school has his own ou where we can find the groups.
A teacher can give lesson in one or more classes. Therefore I need the TextMultiValue, so that we can select more than one classes.
by (16.9k points)
Thank you for specifying. As a workaround we can suggest using only one custom multivalued attribute. In each attribute item value you can specify the name of a school and the name of a class. Alternatively, you can use custom text attributes and specify classes as separate lines. It will look like the following:
For us to provide you with detailed instructions, please, specify which approach meets your needs and post here or send us (support[at]adaxes.com) a screenshot of the Scheduled Task currently used to populate class names. If there are PowerShell scripts executed, please, post here or send us the scripts in TXT format as well.
Adaxes 2021.1 which has 10 more custom multi-valued attributes (20 in total) is released. You can download it here.
What’s New
Upgrade Instructions
Hello, i have an powerhell variable that contains a hashtable. Is there a way to add the content of this hashtable to an adm- ... @{"adm-CustomAttributeTextMultiValue1"=$hashtable} -AdaxesService localhost Thanks for your assistance!
asked Mar 17, 2021 by roppiffm (170 points)
I am looking for a way to view the exact reason why someone would see the error below when accessing the web interface. It would be helpful to see this in a log ... "user attempted to access Web Interface section A, but is lacking the permission XYZ..."
asked Aug 6 by apruitt (580 points)
I have setup a form to allow HR to edit some details on AD accounts. Currently the scope is limted to only AD object under one pre-chosen OU. The other option is an ldap filter. How can I allow this action to display user accounts from two seperate OU
asked Nov 18, 2019 by ice-dog (170 points)
Whilst the Web UI's Custom Forms and Views for each Object Type is useful, it's also very limiting presentation-wise if we want different users, computers, ... user groups and ensure a tidier experience whilst enforcing ACLs on various attributes and objects.
We have a large number of members that we would like to show as part of a Business Unit. I have looked in the config file and found a value that says 500, but wasn't able ... IIS Services to recall the web config and I get the same issue. Version: 3.7.13122.0
asked Jul 1, 2016 by charlesk (20 points)
