I'm trying to make one AD Group to allow access to one of the Web Interfaces I created. When I add that group to the Allowed list under the access control tab on the web interface configuration tool and add a user directly to the group they are able to access the site. When I nest another group inside the "Allow Access " Group members of the nested group are unable to login.
Is it safe to assume only direct members of the AD group I put in the allowed list will be allowed access and any members of a nested group will not be allowed access?
If members of nested groups aren't detected I will have to manually edit this access list for every group we add. I'd really prefer to be able to set this to a single group so I don't have to go into the web interface config tool every time we add a customer.
by (810 points)
Could someone confirm the Web Interface Access Control doesn't look into members of nested groups?
I just want to be sure it's not something I'm missing before I spend a bunch of time creating a work around.
No, this is not the case. Memberships in nested groups are taken into account in the Web interface Access Control.
To troubleshoot the issue, first of all, make sure that you are using security groups only. Memberships in distribution groups are not checked for the Web Interface Access Control. Also, have a look at Adaxes Event Log on the computer where the Web Interface is installed for any errors and/or arnings that may be related to the issue. For information on how to access it, see the following help article: http://www.adaxes.com/help/?ServiceAdmi ... ntLog.html.
Hello all, We've upgraded our Adaxes from 2017 - 2018. One of the sub-sites that have been configured is an "administrator" portal. This portal is restricted to ... to rule out nested groups as a possibility. Any help/direction would be greatly appreciated.
asked Jun 25, 2019 by JHA-Matthew (70 points)
I am evaluating Adaxes. I noticed that the web interface does not allow modification of the External Email Address (ms-Exch-Target-Address). What would someone do if they needed to change the Target Address?
Hi All, We have a reoccuring "Access is Denied" error for our Web Interface sites. This started frequently after upgrading to 2018 version and frequent reboots seem to clear ... the website, restarted the app pool. Still the same error - any advice? Thanks!
asked Jan 4, 2019 by jmarcellus (50 points)
Running 2014.1 here. Is it possible to expose Exchange "CustomAttributes" (may actually be called "ExtensionAttribute" with Ex2013) for viewing / editing via the Web ... then manually add "extensionAttribute#" for each attribute I want to view / edit.
asked Oct 5, 2014 by bradenmcg (260 points)
Hi, how can I configure the Adaxes web interface to accept anonymous access (without username/passwort) ? I need search/query functionality for everyone. I already activated ... How can I suppress the login screen for that interface type ? Best regards Frank
asked Nov 14, 2011 by abc49 (50 points)
3,734 questions
8,631 comments
550,237 users
