Hello all,
We've upgraded our Adaxes from 2017 - 2018. One of the sub-sites that have been configured is an "administrator" portal. This portal is restricted to members of a specific Security Group, "Adaxes-admins" (per se). It is working fine in the 2017 instance, but gives an "Access Denied" when trying to login to the new instance. I can remove access control and login without a problem, however when AC is set for a Security Group, no access.
I've looked at the group itself and my account is a direct member of the group, there are nested groups, but I wanted to rule out nested groups as a possibility.
Any help/direction would be greatly appreciated.
by (70 points)
Hello Matthew,
For troubleshooting purposes, could you, please, post here or send us (support[at]adaxes.com) a screenshot of the Web Interface Access Control settings? We need something like the following:
Any additional details will also be very helpful.
by (70 points)
I can't provide exact details in the public forum, but my access control screen looks exactly like what you have posted, except "MyGroup" is replaced with the group that we would like to allow access to.
Hello Matthew,
Could you, please, make sure that the group is specified under the Allow specific users and groups only option and not under the Deny access for specific users and groups one? If you are not sure, please, send a screenshot to our support email: support[at]adaxes.com.
Hello, I'm trying to make one AD Group to allow access to one of the Web Interfaces I created. When I add that group to the Allowed list under the access control tab on the ... I don't have to go into the web interface config tool every time we add a customer.
asked Nov 2, 2015 by drew.tittle (810 points)
I am getting this error. Please help.
asked Jan 22, 2021 by ComputerHabit (810 points)
Hello, I would like to use pre-defined security groups - Domain User - Authenticated User - Owner (Managed By) for the Access Control during the login. But I have no clue how to define this - all my attempts have failed :( Many thanks, Horst
asked Mar 23, 2018 by HorstR (460 points)
I'm working on building a Telecom web interface for the telecom team at work. I am only have one issue and that's with access control to change the IP phone number. ... IP phones but my non-elevated account has this issue. Any ideas would be helpful. Thanks
asked May 29, 2014 by 7efd721c8b (420 points)
Hi We're experiencing some issues with showing and hiding custom commands when viewing user accounts. We have a number of commands in Adaxes, but no matter the permissions ... other custom commands shown. We're running the latest verison of 2021.1 Thanks Matt
asked Apr 5, 2022 by chappers77 (2.0k points)
