Since we upgraded to the latest version, it seems that role authorization does not work anymore. We have to remove <deny "*"> to make it works again but each time we modify the access list through the Web Configuration UI, <deny "*"> is back again.
Only role authorization fails (using domain group, for instance DOMAIN\Domain Admins), user authorization works as expected (DOMAIN\User)
Thanks in advance
Stephen
by (800 points)
Hello Stephen,
This is a known bug. We've already fixed it in the latest minor update. You can download the update at http://adaxes.com/download_direct.htm.
Upgrade Instructions
We are very sorry for the inconvenience caused.
Hi again, It seems that there is a problem with the Blind Users role and the add to group features : i configured a user as he can see only a specific OU through blind ... " (Where My User stands for the real user name obviously). Am i doing something wrong ?
asked Jul 5, 2011 by sroux (800 points)
Hello all, I'm sure this is possible, but I'm confused on a few points. I'm trying to set up the security role and matching homepage action that will allow a user ... I'd like to use the least amount of permissions possible, just for security's sake. Thanks!
asked Jan 18, 2017 by ctdhelpdesk (190 points)
Hello, after update to 2021.1 we have problems with an old Windows 2003 domain. The service account for the domain will rapidly locked out from the Adaxes server. What we ... in 2021.1 for Managed Domain? Or how can I integrade old domains? regards Helmut
asked Mar 12, 2021 by a423385 (510 points)
After we updated our site to 2018.1 suddenly the Password Self Service link is throwing an error: " Could not load file or assembly 'Softerra.Adaxes.Adsi, Version= ... . The system cannot find the file specified." Other interfaces are workin as expected.
asked Jul 20, 2018 by johnsonua (390 points)
asked Oct 8, 2025 by stevemkoenig (40 points)
