I am trying to run a PS script and get the following error (snipped):-
"Cannot convert the "130978519257589890" value of type "Softerra.Adaxes.Adsi.AdsLargeInteger" to type "System.Double"
How do I convert this attribute?
I have tried converting like this (and get the same convert error):-
[System.Double]$Value = $Value
Note: I'm not sure if I can instead fetch the attribute value as a System.Double type by tweaking the ADSI Get command:-
$Value = $targetPC.Get($targetProperty)
by (1.6k points)
To convert a value of type Softerra.Adaxes.Adsi.AdsLargeInteger to type System.Double, you can use the following method:
$Value = [System.Double]::Parse($targetPC.Get($targetProperty))
By the way, is your ultimate goal to represent the property as a System.Date structure? If so, you can use the following method:
$propertyValue = $targetPC.Get($targetProperty)
$datetime = [DateTime]::FromFiletime([Int64]::Parse($propertyValue))
by (1.6k points)
Many thanks!
Yes, you're right we're trying to pull and display an epoch time. I was using the following PS command, but will also try your solution!
$TimeStamp      = [timezone]::CurrentTimeZone.ToLocalTime(([datetime]'1/1/1970').AddSeconds($Value))
When creating a scheduled task, you select Object type. e.g.: User but can you add an additional filter, eg. where deparment is a value (HR, IT, ...) or where an ... of the CC add an extra pop-up when e.g more information from the requestor is needed?
asked May 11 by LorenzR (40 points)
Hi, I was able to activate the shared folder object type as I browse through a webinterface. Now I face the issue that I am not able to search it via the websearch. Is it possible to add it somehow to the searchable objects? Thanks in advance!
asked Sep 2, 2025 by Marcel Büttinghaus (60 points)
asked Mar 14, 2025 by matt_nz (20 points)
Hello, I'm wondering why i'am missing Domain-DNS object type. Running latest version 3.16.21906.0 (64 bit). I'm running with domain admin & adaxes service ... -custom-commands-scheduled-reports-and-scheduled-tasks-s394.htm This is my Object Type list:
asked Apr 1, 2024 by PeterS (40 points)
