How to delete Intune mobile device that was assigned to %fullname%​ in a business rule?
by (180 points)
Unfortunately, there is no built-in functionality for removing mobile devices. However, using a script with the Remove-MobileDevice cmdlet should work just fine. For information on how to establish connection to Exchange in Adaxes scripts, have a look at the following article in our script repository: https://www.adaxes.com/script-repository/connect-to-exchange-with-powershell-s506.htm.
A User lost device running Microsoft Authenticator. Now user web interface login ends to MFA prompt, but I can't figure out where from a user could ... with allowed Reset Multifactor Authentication and password reset and has enrollet to password reset.
asked Jan 20, 2025 by juhota (230 points)
is this available yet, will it be available at all. any news on an update for Adaxes, the last one was over a year ago.
asked Dec 11, 2024 by i*windows (300 points)
Hello I recently enrolled the "Adaxes Self-Service password reset" manually on about 20 devices (no MDM). It was a mix of iMac's and Macbook's. A few of them ... entirely, but its complicated). Maybe you guys have already experience with that kind of problem.
asked Apr 30, 2024 by Baul (130 points)
We are testing Windows Autopilot and would still like to use the adaxes client to allow for SSPR. Is it possible to configure the Windows Integration settings on a machine that is not domain joined but is joined through Azure AD?
asked Sep 3, 2020 by scoutcor (180 points)
