Im using the "When Marked Inactive" custom property that comes with Adaxes. Im trying to test out the deletion of users using that "When Marked Inactive" attribute, but it will not delete the user.
Im wondering if there is a way to see visually that custom attribute on my disabled Test user.
by (210 points)
by (307k points)
Hello Raul,
Unfortunately, there is no such possibility. The When Marked Inactive property is dedicated only for the built-in scheduled tasks. To achieve the desired, you can use any of Adaxes custom date attributes (e.g. CustomAttributeDate1) and specify a user-friendly display name for it. The attributes work same like AD ones, but are available only in Adaxes.
Hi, I've test auto users desactivation, but mess with some conditions. So i think i've got all of my users with "When Marked Inactive" adaxes properties fill with today date. How can i clear this field for all my ad users ? Best regards
asked Dec 15, 2017 by Nicolas.lussier (190 points)
I have struggled with this custom Adaxes property a little, because it is useful in deprovisioning. When looking at User accounts, the property works via a scheduled task or custom ... a bug? And, will it be possible to look at Adaxes properties in the GUI?
asked Feb 24, 2014 by JoeC (470 points)
Hello, is it possible to view the current value of the "when marked inactive" custom attribute somewhere in the gui? Thanks Regards, Thorsten
asked Jul 6, 2012 by techman26 (240 points)
We use DirSync/AAD Connect (without write-back) and we have some users that use email in the cloud and never authenticate to the on-prem domain controllers. Therefore, we ... has found which one might work the best in an Adaxes scheduled task for example.
asked Jan 31, 2018 by yourpp (540 points)
