we have created some business units which only return certain items in our directory.
when using the web ui, how do we restrict browing functions to only look in the business units that we have defined?
For example, we have a business unit which contains a number of groups and another business unit which contains a certain staff.
when modifying a group, the end user who is adding members to the group should only be able to see people who are members of the business unit, and no one else in the directory. However we dont seem to be able to limit the browsing to this business unit.
if this is not possible, how is it envisaged that these units are used?
by (300 points)
As a solution, you can limit a Web interface to only display the objects that are members of a specific business unit. For details, have a look at section Change top level node of the following tutorial: https://www.adaxes.com/help/PreventUsersFromViewingTheStructure/#change-top-level-node. However, it can only be a single business unit.
Hi, I'm trying to create a web console only for sending SMS using adaxes 2018.2. The SMS-users that are going to use the console should only be able to view users, not edit ... which removes a lot of OUs that the users should not see or be able to browse to.
asked Sep 2, 2020 by eirikza (120 points)
Hello, I want service desk to be able to select from the web interface only groups that are specified in a Business Unit. it is possible to do it (Adaxes 2009.1)? Thanks you.
asked Sep 2, 2020 by tentaal (1.1k points)
I'm trying to rearchitect my Business Units, and I'd like to see if I can export the rules on the current business units in a simple format so I can reorganize them and create new ones. Or at least get the rules and go from there.
asked Sep 9 by ajmilic (150 points)
