Hello team,
  1. The manager is not notified by email about a new approval, only visible in portal
  2. Once the Manager approves it, the whole action is approved How can I build a flow of two approvers? First manager, then owner of target group
by (2.6k points)
Are you sure that the manager of the requestor (the user who initiated the custom command execution) has an address specified in the Email property? Are other email notifications delivered properly?
It can only be done using a separate business rule triggering Before adding a member to a group. For details, have a look at the following tutorial: https://www.adaxes.com/help/RequestApprovalForAddingMembersToGroups. Finally, you should have something like the following the following: image.png
by (2.6k points)
Yes, but I saw an internal issue with our mail server ... none email from Adaxes were delivered (: Solved and now I get an approval notification mail
Does this mean the actions are triggerd one by one and only if first was approved the second will be send out?
Yes, that is correct.
Hello, I want to include in a sent email notification after removing a member from a group the active directory user property "company" and "co" of a user. How can I achieve this? I can not select a property %adm-membercompany% nor %adm-memberco"
Hello, is there a way to save powershell variable to axases attribute and send it via "send email notification" in Scheduled task? for example, check if Office 2016 ... .name) installed"} ` then add $customattrib value to Send email notification. Thank you
asked Feb 13, 2020 by vheper (20 points)
asked Mar 14, 2025 by matt_nz (20 points)
I turned on the option to have "Approve" and "Deny" links sent in the approval request email. It seems to not be working through. Here is a screenshot of what it ... the link. I also tried using incognito mode in chrome. Same look. Appreciate the assistance!
asked Mar 29, 2021 by mark.it.admin (2.3k points)
HI, I have scenario to perform a custom action based on the notification approval result. Before creating a user, i need to send out for an approval, if the request ... there a way we can achieve this. Any help/pointers or references would really appreciated.
asked Mar 4, 2016 by ramd123 (50 points)
