I want to be able to create a custom action that allows, via the web interface, a user to increase the size of his/her own mailbox by say 10% or 20%. What would be the best way to go about this?
by (280 points)
Hello Dominik,
What exactly do you mean by size of his/her own mailbox? There are storage quotas in Exchange, but there is no way to increase/decrease a mailbox size. It just depends on the stored objects.
by (280 points)
Yes, the storage quotas is what I'm refering to, sorry for the confusion.
Hello Dominik,
Thank you for clarifying. Unfortunately, there is no easy way to do that according to percentage. Such a thing can only be done using a script. However, you can use a custom command to easily set specific numbers. The following tutorial (Example 3 – Configure storage quotas and deleted item retention) will be helpful: https://www.adaxes.com/help/AutomateExchangeMailboxConfiguration. For details on how to create custom commands, see https://www.adaxes.com/help/CreateCustomCommand.
password reset emails - i need my company logo in the email - it does show up if you click on download pictures - but i cant ask the users to do this - so need to know if there is a way to embed the image in the email from adaxes.
asked Jul 28, 2021 by Nick Davis (20 points)
I'm trying to rearchitect my Business Units, and I'd like to see if I can export the rules on the current business units in a simple format so I can reorganize them and create new ones. Or at least get the rules and go from there.
asked Sep 9 by ajmilic (150 points)
asked Feb 4 by Keshstew (20 points)
We need to have a process to revoke the access token used by Okta for end users.
asked Jan 22 by william.malone (100 points)
