Users when signing into the adaxes portal, MFA keeps saying invalid. I have had to disable MFA for now till we can get this resolved.
What exactly do you mean by MFA keeps saying invalid? Could you, please, provide a screenshot of the error? You can post it here or send to us at support@adaxes.com.
Here is the issue i'm having no one in the company can access the website using MFA. I had to turn it off for it to work again.
Thank you for the provided details. The only possible reason for the behavior is time synchronization being turned of either on the user devices or on the computer where Adaxes service runs. You need to make sure that the synchronization is enabled properly. Pay attention that setting the time manually will not work.
I looked at our server and the PC's they are in the same time zone and everything. Is there anywhere else I need to check?
It is not about time zones. It is specifically about time synchronization being enabled on the computer where Adaxes service runs (not where the Web interface is installed or any other) and on the user mobile devices. The following thread from Microsoft forums should be helpful: https://answers.microsoft.com/en-us/windows/forum/all/how-to-force-windows-10-time-to-synch-with-a-time/20f3b546-af38-42fb-a2d0-d4df13cc8f43.
Sadly those methods did not work for me. Seems they are out of date as well.
Unfortunately, we were not able to find an exact article by Microsoft. You might just check with their support team. We can only state that the issue you are facing can only be related to time being out of sync on the computer where Adaxes service runs or on the mobile device where the authenticator app is installed.
Hi all, We currently have a bunch of dial plans that we assign to new users via Adaxes. We updated Adaxes to the latest version, and moved it to a new server before ... value - perhaps this value has been removed/broken in new versions of adaxes? Cheers all.
asked Jan 22, 2024 by TheLexicon (200 points)
Hi We're experiencing some issues with showing and hiding custom commands when viewing user accounts. We have a number of commands in Adaxes, but no matter the permissions ... other custom commands shown. We're running the latest verison of 2021.1 Thanks Matt
asked Apr 5, 2022 by chappers77 (2.0k points)
I enabled 2FA for common signing and it's applied to each portal. I am using separate account for testing purposes to see how changes affect for other users and for everyday ... possible? I am also wondering how to reset and/or remove 2FA from test account?
asked Dec 23, 2020 by juhota (230 points)
Hey we have a multi-domain AD forest and I'm trying to use powershell to remove computers in the child domains from a universal group in the root domain. I tried it with naming ... I run this in Ps5.1 or Ps7, from my laptop or from the Adaxes server itself.
asked Oct 17, 2025 by felix (230 points)
