For example, if their old password was "Password1", if they try to change it to "Password2" it would block the password reset since it doesn't meet the password requirements.
Unfortunately, the script will not be helpful. The thing is that there is generally no possibility to obtain the current password of a user. As such, there is no way to compare it with the password being set like in the example.
Unfortunately, there is no such possibility in Adaxes. However, you can try enabling password history in your AD domain password policies.
I know I can set the "User must change password at next logon" flag, but noticed when I do that, they can no longer log in to Self-Service.
asked Oct 1, 2020 by RickWaukCo (320 points)
Hello, I'm wondering if there is something like the calculated property "%adm-RandomString%", but that also includes symbols. Is there another command that accomplishes this task, or ... 's characters? Any way I could get this done within the realm of Adaxes?
asked Jul 7, 2022 by NKB#2772 (70 points)
