Hi.
How can we assign O365 licence to Room mailbox (exemple teams room device)?
Activate / modify Office 365 property step is not available on that kind of object.
Therefore, we cannot use a custom command to set the licence and do other stuff on that kind of object.
by (60 points)
by (16.9k points)
Update
Starting from Adaxes 2025.1, the Microsoft 365 section can now be added to forms and views for room and equipment mailboxes. As a result, you can use native functionality to assign/revoke licenses from the mailboxes.
You can download the new version of Adaxes here.
Upgrade instructions
What's New
Original
Unfortunately, there is currently no possibility to manage Microsoft 365 properties (including the Microsoft 365 licenses assignment) of resource mailboxes in Adaxes. Thank you for the suggestion, we have forwarded it to the corresponding department for consideration.
by (2.7k points)
Would it be possible via Custom Command and this PowerShell script? https://www.adaxes.com/script-repository/assign-office-365-license-based-on-availablity-s472.htm
by (16.9k points)
+1
Yes, it is possible to assign a Microsoft 365 license to a room mailbox using the mentioned script. Pay attention that you need to create a custom command configured for the Room Mailbox object type to be able to execute it on room mailboxes. image.png
Hi, based on this article How to create Resource Mailboxes a few slide modifications aside we are currently creating resource and equipment mailboxes in our on-premise environment. ... to O365. Does this work at all? Appreciate your input. Kind Regards Ingemar
asked Oct 26, 2016 by ijacob (960 points)
It appears that we can allow conflicting meetings on a room mailbox but can't set the number of allowed conflicts. Is this a bug or intended? Can we request this feature? Do ... to create a custom command for this? We are on version 3.14.19723.0 Thanks, Mark
asked Jul 13, 2022 by mark.it.admin (2.3k points)
Hey Guys We have some issues with new meeting rooms that we have created. Previously we used to have on-premise exchange but switched to office365. Before doing ... OU but the interface are different. under exchange properties they are different aswell.
asked Sep 18, 2019 by seanr (70 points)
How would a script be written that accomplishes the following task? In this scenario, UserA would be selected with the Modify user action, then UserB would be input to ... rule that runs the script to allow reviewer permissions on UserA's calendar for UserB
asked Dec 6, 2012 by mdeflice (350 points)
Hi, I was wondering if there was a way to generate a widget type block/or a report on the Adaxes homepage displaying the number of free licences for a specific (or all) ... are the most important information if there's a way to report on that. Thanks, Gary
asked Feb 8, 2023 by gazoco (490 points)
