We currently convert user mailboxes to shared mailboxes during deprovisioning process but if the user mailbox was already a shared mailbox then the script throws an error because the mailbox cannot be converted to a shared bailbox.
How can I add a condition to the script to avoid the error? Also I would like to add a custom command to convert the user mailbox that is already a shared mailbox back to a user mailbox.
Here is the actions of the current deprovision command: image.png
by (50 points)
by (16.9k points)
Hello Carlos,
According to the provided screenshot, you are using the Convert mailbox built-in action. The action should not error out if it is configured to convert the user mailbox to a shared one and the user already has a shared mailbox. For troubleshooting purposes, please, provide us with the following:
  • A screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment.
  • A screenshot of the error you are facing.
You can post screenshots here or send us at support@adaxes.com.
You can use the Convert mailbox action configured to convert the user mailbox to a regular one. image.png
by (50 points)
here is a screenshot: image.png
by (16.9k points)
Hello Carlos,
Sorry for the confusion, but the provided screenshot does not contain the Multi-server environment dialog or an error. Please, follow the instructions in the provided help article to view the Multi-server environment dialog. Additionally, for troubleshooting purposes, we need a screenshot of the error you are facing when the Convert mailbox of the user into shared mailbox action is executed on an account that already has a shared mailbox.
Hey Guys We have some issues with new meeting rooms that we have created. Previously we used to have on-premise exchange but switched to office365. Before doing ... OU but the interface are different. under exchange properties they are different aswell.
asked Sep 18, 2019 by seanr (70 points)
The built in functionality to convert exchange online mailboxes to shared does not work for users that are synced from our local AD via Azure AD connect. How can we over ... account to in cloud from synced with AD all our issues with this would be resolved.
asked Jul 31, 2019 by john.morrow (270 points)
So if we change the flow on the exisitng deprovision script to the above, is there a way to set a retention policy tag to the converted mailbox? Our standard retention is 90 days.
asked Sep 19, 2024 by EnbyAdmin (60 points)
Looking for a script (unless there is a built in way, which I don't think there is) to grant User A full access to User B's OneDrive
asked Dec 16, 2024 by msheppard (880 points)
